XERUN V2.0 Brushless ESC discussion thread. >
Old 02-15-2010, 02:36 PM
  #211
cherry2blost's Avatar
Originally Posted by gazmond View Post
Howdy Folks,
Couple of questions regarding using the SP software instead of the HW's. Does the SP package auto-update? What I mean is if the propsed changes to the SP software lock out XERUN users from using it in the future are we going to forever have to be wary of any auto-update feature? Coupled with that when you flash to one of the newer profiles is it downloading that from the net or is the profile config contained within the softrware package?
Cheers
Gaz
No you have to physically download and reflash the programming card each time new software is released. There is a tab on the HW controller for update but it never works. So no you should see no problems mate.
cherry2blost is offline
Old 02-15-2010, 02:46 PM
  #212
Thanks bud, 1 more question :P does the software you linked to in an earlier post hosted on filefront work with a XERUN 60a?
gazmond is offline
Old 02-15-2010, 03:32 PM
  #213
Yes the 60amp Xerun is basically a Speed Passion GT2.0 LPF specs are the same so yes the software will run on the 60amp, but use a fan on the ESC if you are running the really hot software, just in case that's all.
Have fun coz the SP software is WAY quicker than the standard software.
Old 02-16-2010, 02:12 PM
  #214
Hi, cherry2blost.
Many thanks for the SP link I have done so and the 13.5t stock will have many revs more than ever before, thanks man.
I have also downloaded the MOD version and this software make the engine I have a big screamer (healthy sound and more powerfull) this engine did not make the revs before as it do now.
I am curious how it behave on the track stock as well as mod.
Ed
eded1 is offline
Old 02-16-2010, 04:12 PM
  #215
unsp0ken's Avatar
Trader Rating: 25 (100%+)
so do i need to update my programmer box to a SP version before i can load the SP firmware onto my esc? or will it work with the HW 1.02 program in the programmer box?
EDIT: nm, i was able to load the sp 110 software with the 1.02 firmware in the programmer box.
unsp0ken is offline
Old 02-16-2010, 08:04 PM
  #216
Akudou's Avatar
Anyone can recommend me which firmware to use on my 120a? Its running a 11.5t motor. Thanks
Akudou is offline
Old 02-17-2010, 12:51 AM
  #217
SP 110 or 107.
Use 110, Timing at 26.25. DDRS at VI or VII gear at about 5.8ish and start from there, if it's a small track obviously come back up to the 6's or a huge track then down to the mid 5's but that should be an ok start point.
Old 02-17-2010, 08:50 AM
  #218
Akudou's Avatar
Thanks for the reply. Just tested on 107 before i had the chance to read your reply. Track is a fast technical track, so i geared it down to 5.2 with DDRS-9, timing-26.25 and temps are at 62c after 5 minutes. Doesnt seem enough for me as im trying to tune it so that i can keep with the the others who are running rbs and sxx stock spec. Heard the 107 is better than the 110? Any differences?
SP 110 or 107.
Akudou is offline
Old 02-17-2010, 09:08 AM
  #219
Born2Run's Avatar
With 107 software ,DDRS-9 and timing 26.5 ,temps sould be higher than 62c.I sould try DDRS-VII,timing 22.5 geared up to 4.4-4.8. 107 runs almost 15c hotter than 110.
Born2Run is offline
Old 02-17-2010, 09:12 AM
  #220
Have you added physical timing to the motor yet?
Old 02-17-2010, 08:29 PM
  #221
Akudou's Avatar
You mean the timing on the motor? I know most new motors built nowadays have timing setting on it but i cant seem to find any on my Team Powers 11.5t. Or are you talking about the AMTS on the esc?
Akudou is offline
Old 02-18-2010, 12:17 AM
  #222
eceer's Avatar
What speedie settings & FDR's are people using for 107/110 SP firmware for a 17.5t .
eceer is offline
Old 02-18-2010, 12:51 AM
  #223
Do you have the Team Powers sensored or sensorless motor? could be important.
I run Novaks and Fantoms, both have adjustable timing on the endbell we just crank that up a little to gain more top end.
Old 02-18-2010, 01:32 AM
  #224
Born2Run's Avatar
He must be running sensorless,thats why he cannot see how to adjust timing on the endbell.But temp 62c with the 107 software and these settings on esc sounds wierd to me.
Born2Run is offline
Old 02-18-2010, 02:59 AM
  #225
Hi Guys
First off, Thank you to those who have obviously done their homework and are willing to share their learned knowledge with the rest of us.
Most of us in our club traded in our silver cans and Ni-Cads for Hobbywing 60 amp 17.5 combos back when they first came out they were all were all version 1's, we ran a fixed gear ratio. Lipos were in their infancy. IMO it has produced some of the best racing in our club and even still today. Those who trash this product are surely not speaking from experience but from their bottoms.
I was able to install the SP ver. 1.32 software with my LCD box V 1.02. I have 2 questions maybe someone could answer for me. What is the advantage of flashing the box with the SP software?(Tried that but the box was not happy at all) The "Mode's 0-1-2" are only for storing the programmable settings not different software versions, correct?(I had high hopes but...)
Hope HW will produce a high end software for HW users soon
Thanks for you help Joe
TBOTubed is offline
