XERUN V2.0 Brushless ESC discussion thread. >
Old 02-01-2010, 09:35 AM
  #136
razzor's Avatar
change the firmware using Speedpassions software. note SP also has a new version.
razzor is offline
Old 02-01-2010, 10:13 AM
  #137
Born2Run's Avatar
I instaled the latest software update form HW and upgrated the USB Link.Now The LCD software version is v1.04_091225.When i try to brink back the previous version v1.02 im getting a popup window that says "The current version (v1.04_091225) can not be updated to the version (v1.02)".I want back the v1.02 but i can get it.
Born2Run is offline
Old 02-01-2010, 11:30 AM
  #138
cherry2blost's Avatar
Anyone care to give a linky for the 'NEW' SP software, above. THANKS !!!!
cherry2blost is offline
Old 02-01-2010, 12:45 PM
  #139
Born2Run's Avatar
I don't think SP has release a new software update.Hobbywing instead will release on 7 Feb. 2010 their new 100110 for stock.
Born2Run is offline
Old 02-01-2010, 01:02 PM
  #140
Likely to be any different from the SP 110 that I am running at the moment I wonder ?
Old 02-01-2010, 09:38 PM
  #141
Born2Run's Avatar
It sould be different but since we haven't try it yet we cannot be sure.
Born2Run is offline
Old 02-02-2010, 05:11 AM
  #142
HELPPPP!!! I have updated my LCD program Box to the v.1.04_091225 How i can return to the previous version v.1.02? Anybody pls?
Hello sir. Why do you want to return to the old version?
february is offline
Old 02-02-2010, 08:00 AM
  #143
Born2Run's Avatar
Because my ESC now is dead.I was using the v1.02 since Sunday.Then something happened ( a crash)and the ESC lost the 70% of its power,lost the brakes also and reset itself.I tried everything and finaly i thought to instal the latest software form Hobbywing (v 1.6) and to upgrade the LDC from the v1.02 to the latest one
v1.04_091225 but when i did it the ESC died.No sounds, no throttle only steering and error blinking LEDS.I have already ordered a new XERUN 120 but im not sure if only the ESC has been damaged or even the LCD program box because of something that i did wrong.Before use it with the new ESC i would like to check it with the old one just to be sure that it works and that it will not send wrong data to the new one and to damage it.
Born2Run is offline
Old 02-02-2010, 10:41 AM
  #144
razzor's Avatar
try and reload firmware. if it doesnt work then there is something wrong with the esc itself not the firmware/software.
razzor is offline
Old 02-02-2010, 12:09 PM
  #145
Born2Run's Avatar
I have try many times with different firmwares but nothing.Speedo is dead.I hope it's only the speedo and not the program box too.
Born2Run is offline
Old 02-02-2010, 01:24 PM
  #146
AGNO's Avatar
Where can I find the version v1.04_091225? In my version V1.6 is not there.
AGNO is offline
Old 02-02-2010, 09:13 PM
  #147
Born2Run's Avatar
You must download from HW and install the v1.6_091229 software.Then under the software tab choose Upgrade and thats all.
Born2Run is offline
Old 02-03-2010, 01:00 AM
  #148
razzor's Avatar
when you open the software you need to select "2 in 1 program box" under the "device" tab.
Then select the hand programmer firmware and install/load it.
I am using it on both the Xerun and my Sp speedcontrols.
razzor is offline
Old 02-03-2010, 01:20 AM
  #149
Howdy folks,
Looking at getting my first BL system after recently getting in to 1/10th TC's and this is currently top of my list due it's price as I don't want to spend a fortune on my first system. I currently run in the stock 17.5 class but will look to move up to the 13.5t class soonish, will the 60a V2 handle a 13.5t motor ok? Also I am looking at pairing the ESC with a sensored losi xcelorin 17.5t motor (someone at my club is going to give it me for a very good price) will they work together ok?
I take it the 60a HW is basically the same as the SP LPF?
Thanks in advance for any help!
gazmond is offline
Old 02-03-2010, 01:26 AM
  #150
razzor's Avatar
The 60amp Xerun will be fine for stock classes. just get the software updated by someone at your local track or hobbyshop.
razzor is offline
