Old 07-14-2009, 08:25 PM   #1
drive2survive's Avatar
Trader Rating: 23 (100%+)
Default DB12R INFO
hey guys new to this site but long time modeler and now getting into cars, like 1/12.....the owner of a BMI db12R and have had the car out a couple times to see how it acts. been practicing with cones to get some skills... straight away speeds are almost outta control and Im not even at full throttle! anyway gunning it on a straightaway, the car wants to weave off course ,,,, question is what causes the car to do this, is it a torque problem? or is that a normal thing with cars
I havent studied the mechanix of the car or tires yet so am just running blind trying to figure things out, would appreciate any info re this car
drive2survive is offline   Reply With Quote
Old 07-14-2009, 08:27 PM   #2
protc3's Avatar
It sounds like the rear axle is not shimmed correctly. It needs to be centered perfectly. Next, you need to make sure that the surface is clean and not dusty
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 07-14-2009, 08:34 PM   #3
chris moore's Avatar
Trader Rating: 88 (99%+)
What Jason is refering to is known as torque steer and as he said happens if the axle is not centered. Measure from the small hole in the bottom pod plate to the outside of the tire on each side, add shims untill both sides are equall and the total width does'nt exceed 172mm; calipers are the easiest way to do this. It can also come from a few other things like improper diff adjustment, and tires that are different sizes side to side.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 07-14-2009, 09:31 PM   #4
Da now I get ya... thanx
Old 07-14-2009, 09:36 PM   #5
Are you driving it on a race track or some parking lot or street somewhere. The traction levels are much different and much of the advice you see on this forum is geared for people running on a track that has at least some preparation. If your not running on a track you may need some softer rear tires or traction compound to get more grip out of the rear tires.
Old 07-14-2009, 10:06 PM   #6
Ive been running on an asphalt parking lot that has been blown off but still thiers tiny pebbles, and the car manages to find every one! like I said, just trying to get enuff skill so I can show up at the local track w/o looking too stupid LOL so what color are the softer tires? lots to learn keep the info comin, and thanx
Old 07-14-2009, 11:56 PM   #7
Trader Rating: 14 (100%+)
drive2survive--- Please don't sell your local race track short. The only true way you are going to obtain "Skills" is actually get on a controlled racing surface and "setup" your car to the track. Some of best advice I have ever gotten was when I first started racing. There are more than enough guys that are willing to help you. And I'm willing to bet you they will be excited to see you succeed. Hope I have helped!
Also look at the rear of the car. On the bottom plate you will see a small hole in the graphite. That should be the center of the car. Now measure from that hole to the outside of your tire on one side. And then do the opposite side. You may need to add "shims" to one side or the other to get what the other guys are talking about (torque steer)out of the car.
PM me if you need anything else.
SwampDog32 is offline   Reply With Quote
Old 07-17-2009, 08:08 PM   #8
....that spacing thing worked out good,and yes thier even, just took awhile for the light to come on LOL Ha, lots to learn
Old 07-17-2009, 10:09 PM   #9
Glad I could help. The only way to gain knowledge is ask. Good luck.
1/12 forum ovalnator Electric On-Road 46184 Yesterday 09:37 AM
The future of 1/12 scale Roland S Electric On-Road 1004 06-16-2017 02:04 PM
BMI's DB12R Mr. Shookie Electric On-Road 8730 02-11-2017 12:12 PM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 08:38 PM
TriState Hobbies & Raceway, Cincinnati, Ohio RBLove Racing Forum 3306 12-21-2010 08:02 AM
1/12 CARPET KNIFE INFO drive2survive Electric On-Road 13 07-16-2009 06:38 PM
