Old 07-13-2009, 09:29 PM   #1
cjmonkey's Avatar
Default Setup Station vs Camber Square
Ive noticed a big discrepancy between my Hudy 1/10 setup station and my camber square.
If i setup my camber according to my hudy station, and then measure it with the camber square, i usually se a difference of about 1-2mm!
My question is... which should i believe? Could it be that my Hudy is reading the camber correctly, but the tolerances in my wheels/tires are causing an inaccurate reading on the guage?
How do you guys set your camber?
TAMIYA - LRP - Speedpassion - Sorex - Futaba - Protoform - Intellect - Muchmore
DEM Racing Team
W.E.R.C
cjmonkey is offline   Reply With Quote
Old 07-13-2009, 09:53 PM   #2
pakk's Avatar
Trader Rating: 79 (100%+)
I don't use those square because most of my wheels are bent from hitting stuff. So I just use the setup station.
But ideally, if your wheels are strait, they should read the same. Have you checked your wheels?
--pakk
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 07-13-2009, 09:56 PM   #3
JimmyMac's Avatar
When you use the "square" you should also use setup wheels. If you do not, then a bent wheel will cause inaccurate reading/settings. My setup wheel/guage have been dead on with my setup station.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 07-13-2009, 09:59 PM   #4
pakk's Avatar
doesn't that defeat the purpose of a square? I always thought of the square to be a good quick way to check your settings. If you are taking your wheels off and putting a set of set up wheels on, aren't you better off just using the setup station?
--pakk
*Photon* *SC10 4x4*
RCRD
Old 07-13-2009, 10:07 PM   #5
cjmonkey's Avatar
i noticed this with brand new wheels... :-(
DEM Racing Team
W.E.R.C
Old 07-13-2009, 10:26 PM   #6
JimmyMac's Avatar
--pakk
Yes and no. It's much easier to pack up 4 setup wheels and a camber gauge compared to a whole setup station. In other words, my 4 setups wheels and camber gauge only take up the space of one rubber tire in my pit box. Where as my setup station is in a case by itself. Blah blah blah. hehe. But you can just use a setup gauge/square on normal wheels/tires. But you must rotate the tire 1/4 turn and measure it. 1/4 turn and measure it. 1/4 turn and measure it. If your readings are inaccurate, your wheels are warped. This is why it's best to use setup wheels. Also, with setup wheels, they are usually 1mm taller than tires. So you can set ride height up evenly at all 4 corners as long as you know the difference between your setup wheels and actual wheels. There are even setup wheels for carpet racing. They are setup to mimic foam tires cut at different heights, like 56mm or 58mm or 57mm, etc, etc. So you can setup droop/lift or ride height accurately. Etc, etc.
Anyways, at the track, I use setup wheels and camber gauge. At home, I use setup station.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 07-13-2009, 10:33 PM   #7
pakk's Avatar
What are these "set up wheels" you are talking about. When you said it the first time, I thought you mean you had a set of reg wheels that you knew were strait. Now it sounds like something else.
....and your logic makes sense. Space is huge. I have been trying to minimize what I take with me. I found the best way is to pit next to someone who brings everything and become their friend.
--pakk
*Photon* *SC10 4x4*
RCRD
Old 07-13-2009, 10:50 PM   #8
JimmyMac's Avatar
I use this...
http://www.speedtechrc.com/store/ebp...id=613&id=5782
Along with this...
http://shopping.rcmodel.hk/product_i...oducts_id=6538
or this...
http://shopping.rcmodel.hk/product_i...ducts_id=10400
There are many different makes of setup wheels.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 07-13-2009, 10:51 PM   #9
cyanyde's Avatar
http://cgi.ebay.com/3Racing-ST-001-P...A1%7C294%3A200
/Adrian.
RC FB Pages Subscribed:
facebook.com/EPBuggy
facebook.com/AllStarChampionship
cyanyde is offline   Reply With Quote
Old 07-13-2009, 11:03 PM   #10
FK05 lover's Avatar
Trader Rating: 147 (99%+)
you should only use the camber square on set up rims or disc's on on tyre/rim as you will get a different reading
CastleHill Raceway...
FK05 lover is offline   Reply With Quote
Old 07-14-2009, 12:31 AM   #11
cjmonkey's Avatar
thanks for the info guys..
DEM Racing Team
W.E.R.C
Old 07-14-2009, 04:18 AM   #12
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
a setup system / setup wheels never show the same camber value, your actual race tires do, even if they are new and flat
it's just caused by the load
a setup system / setup wheels tend to "slide out" compared to a real wheel which in the end results in 2 set on a setup system beeing REAL 1 - 1.5 of camber depending on the slop in your car
so if youw ant to have 1.5 of real camber (which is somewhat a desired value usually) you have to set around 2 on a setup system depending on your system/car
this should also make you think about wether or not a setup system is usefull ...
most of the time a cheap camber gauge is best as you can measure the real camber on the wheels you use in the race, rotate the wheel by 1/3 of a turn and measure again, rotate again, measure again
this way you make sure you even take a bent wheel into consideration
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 07-14-2009, 09:13 AM   #13
94eg!'s Avatar
Trader Rating: 17 (100%+)
^Yes that makes very good sense. A setup wheel will load the wheel bearings very different from a real tire/wheel. It sounds like the setup wheel mimics the load seen by the inside tire during a turn (the bottom is being pulled outwards). If -1.5* camber is set like this, the play in wheel bearing/hubs can/will reduce camber to near zero on the outside wheel when racing.
I have also noticed it makes a similar difference when simply setting the car down onto the setup board. The stickier the tires, more they grab & pull as you set the car down...
So here's the real question: If you were to place the car for measuring so as to take up all the slack, which would be the better direction.......Bottom of wheels pulled in towards eachother, or bottom of wheels being pulled outwards?
94eg! is offline   Reply With Quote
Old 07-14-2009, 09:27 AM   #14
the real deal ... in racing condiitions the tires will never slide out!
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 07-14-2009, 09:47 AM   #15
sportpak's Avatar
Trader Rating: 26 (100%+)
The most important thing is to do it the same every time. if you worry about setup wheels varying from actual, if you do the same thing each time, your numbers will end up whatever they end and your car will be setup.
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
