Old 07-14-2009, 01:35 PM   #16
Foxxrocket's Avatar
Rubber tires will last you a vary, vary long time. I usually buy new tires after every other race event, but I still have tires that are a few sessions old. You will never have to worry about rollout, gear changing to tire diameter, or tire shaving, with rubber tires. Just brake them in with a few hot laps, until the center seam is gone.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 07-14-2009, 01:38 PM   #17
jhwnissan's Avatar
Originally Posted by ep10 View Post
Thanks for info! I like rubber myself too.
What kinda tire sauce do you suggest? Are there any different between the one for rubber and for foam?
I just use Paragon for carpet.. I've never used it too much on asphalt but I believe it will work as well... anyone else used it without trouble?
Josh Howard on RCNEWB.COM
Drawing rc car body madness in a Bunker....
Rare Losi R/C Belt Maker Extraordinaire
Need belts or parts? I can help.
SWs, RWs, XX-4s, XXX-S
jhwnissan is offline   Reply With Quote
Old 07-14-2009, 01:45 PM   #18
i use LRP Asphalt for outside
and the LRP Carpet for indoors
tried it without ..... crashed and bust a suspension arm .........
went out with the sauce on and went fastest .....
wont go out without it again
put it on , stick the tyre warmers on for 20 to 30 mins and wipe the reserve off and go thrash the arse off it .........
sidecarphil1 is offline   Reply With Quote
Old 07-14-2009, 02:37 PM   #19
Trader Rating: 21 (100%+)
What the track will allow.
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 07-22-2009, 11:46 PM   #20
ep10's Avatar
How often do I need to use the tire sauce?
ep10 is offline   Reply With Quote
Old 07-23-2009, 04:28 AM   #21
tc3team's Avatar
This depends mostly on the grip level of the track.
For example, indoors with foam, I use 40 shore tyres (hard) and only apply additive for the first round of qualifying. The reason for this is the grip comes up through the evenings racing, so applying any more additive usually results in a car that is too twitchy, or even worse, grip rolls.
Although for example, outdoors on rubber you may need additive on for every race, because grip levels are low. (cold/wet track, or rain has washed away all the grip the track had previously).
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Mini/Micro RC S-T-R-l-K-E-R Manila Racers 7365 06-03-2017 07:16 PM
Mugen MTX-3 university_dave Nitro On-Road 17237 12-30-2012 01:16 PM
1/8 buggy slicks tubehead Nitro Off-Road 7 01-09-2008 09:56 PM
Team Integy Automatic Tire Truer domo Australia For Sale/Trade 7 04-03-2007 02:29 AM
Rubber Tire touring car racing... Nexus Electric On-Road 183 06-18-2006 08:41 PM
