Ask Todd Hodge..aka "Hodgimoto"
#1381
Todd,
I just picked up the HD Black belt kit for the XXXS. Do you cut the teeth on this belt like the old one or do you just run it with all the teeth? I'm running mod foam.
#1382
Slow-
Most guys won't cut the teeth in mod, the belt is more likly to slip, If you do you will have to run it tighter, in turn your drivetrain will no tbe as free, Most of the guys do this in stock or 19T to help free the car up in the corners and maintain better corner speed. It also makes the belt a little more brittle. I broke a black belt two weeks ago in 19T that I had cut the teeth, You are probly better off just leaving it.
Red Rocket
Red Rocket
#1383
anyone know if there is an aftermarket shock tower for the xxx-s that has a lower set of shock holes + the regular shock holes in them. just seems like it would be easier to get more shock travel and droop out of your car rather than going thru all the trouble in making your shocks longer for those small dia foams I like to run. I like to run the foam down to the rim! and Im running out of thread on the shock shaft.
#1384
Go here for the tower you need.
http://www.teamprpracing.com/xxxs.html
I have run these for 2 years now. Good luck
Brant
Brant
#1385
Brant
In the description of those towers it says the they have the stock row of holes a above. I need the additional holes below the stock holes. my foam tires are about to the rim and I need more travel so I can set the proper ride height and droop. holes need to be below stock holes.
Greg
Greg
#1386
Hey Todd,
Congrats on the A-main finish in Cleveland! It looks like the new car was doing great for all you guys out there. Can't wait to get my hands on it.
With regards, to the new car, it seem like every one I see team drivers running has aluminum arm mounts, while the production pictures on the Losi website show plastic/graphite ones. Are the aluminum mounts going to be available as a hop up? Thanks for the info!
#1389
Originally posted by rcman6
Brant
Greg
Brant
Greg
Brant
#1390
Brant
I understand what your saying but the lower set of holes on the PRP shock tower are the same as the stock holes on the losi shock tower. Im looking for a tower that has holes below losi stock holes. I have foam tires that are 51mm in dia that I want to run but Im having a hard time geting my droop set. Im running out of shock travel.
#1391
Brant
Brant
Brant
#1392
Originally posted by Rich Trujillo
What up Hodgimoto
What up Hodgimoto
#1393
What font did you use in your avatar?
#1394
#1395
Originally posted by Hodapp
Wow!! The great Richard Trujillo finally joins rctech after all of these years. It must be so he can show off his new avatar. Nice work by the way. Looks like all that schooling is starting to pay off. LOL
