Ask Todd Hodge..aka "Hodgimoto" >
Old 10-14-2004, 11:51 AM
  #1246
imjonah's Avatar
Default Basic info about OneWays
I just bought a one-way for my XXX-S.
I assume from looking at the published setup sheets that one ways are used on large tracks with fast corners primarily asphalt outdoors.
I wonder what specfic changes one should make when switching to a one way.
I have read that they are more difficult to drive, I am worried aobut that because I am just learning how to drive but I thought maybe it was best to work on my driving with the one way installed rather than convert to it later after I got use to one style of driving.
Even thought I do not see any setups for tight carpet tracks which use a one way; is it a problem if you are running on a tight carpet track to have a one way installed?
imjonah is offline
Old 10-14-2004, 11:01 PM
  #1247
Still Bill's Avatar
Trader Rating: 16 (100%+)
Default Re: Basic info about OneWays
Imjonah,
A spool offers a lot of performance...great accelleration out of corners...And is a lot easier to get used to...It does have braking whereas a one-way doesn't.
Pulling the balls out of the front pulley and replacing them with the sandpaper pads is an easy task.
I would say it gets you way beyond halfway towards running a one-way with a lot less hassle.
Still Bill is offline
Old 10-14-2004, 11:23 PM
  #1248
POOKYT's Avatar
Originally posted by Randy Caster
So that's what makes you Losi guys so damn fast
With 10676 posts I would think anyone who ever ran a Losi knows Randy! Good Lord!
Brant
POOKYT is offline
Old 10-14-2004, 11:29 PM
  #1249
Still Bill's Avatar
Brant
And James Nguyen...
Old 10-14-2004, 11:40 PM
  #1250
POOKYT's Avatar
Originally posted by XXX-S Bill
And James Nguyen...
DITTO ! Thanks Bill
Brant
POOKYT is offline
Old 10-15-2004, 07:23 PM
  #1251
imjonah's Avatar
Am I correct that a one way is primarily for high speed cornering and is most commonly used on outdoor asphalt tracks and not recomended for tight carpet tracks with foam tires.
What exactly is it that makes a one way hard to drive?
The fact that if one is use to a driving s diff that it takes time to adjust or is there something inherently more difficult to drive an one way?
Is it just the loss of half your braking or does braking only on the rear wheels make the car hard to control?
imjonah is offline
Old 10-15-2004, 07:37 PM
  #1252
Todge
Whats the internal ratio for the new sedan?
Was it design to max. legal width? Just wondering if I'll be able to use my TC3 hex wheel adapters.
thanx 4 reply
dasupacat is offline
Old 10-15-2004, 08:28 PM
  #1253
J.Filipow's Avatar
Trader Rating: 15 (100%+)
imjonah- Typically, a one way assembly is used to gain steering without sacrificing too much rear bite. A one way will work better in low speed cornering compared to a diff; a spool might have an advantage compared to a one way on track with a lot of high speed/sweeping corners. It depends on the track layout and the available traction. A one way can take some time to get used to driving if you are not familiar with how it feels; you can't drive too hard or too deep into corners, and yes, braking with a one way is also achieved with practice.
I can't imagine wanting to use a one way on a carpet track; usually the correct tire choice can get you the steering/rear bite combo that works well.
J.Filipow is offline
Old 10-15-2004, 11:28 PM
  #1254
POOKYT's Avatar
Originally posted by dasupacat
Todge
thanx 4 reply
I am 99% sure Todd said that the ratio is the same 1.83. The diff pulleys are the same and the mid pulleys are the same tooth count as the XXXS spur/pulley is now. Correct me if I'm wrong guys.
Brant
POOKYT is offline
Old 10-16-2004, 06:13 AM
  #1255
So ...I wonder if that's a 128T spur on that car.
Old 10-16-2004, 07:02 AM
  #1256
POOKYT's Avatar
I'm pretty sure it is a 128 spur.
Brant
POOKYT is offline
Old 10-16-2004, 04:40 PM
  #1257
imjonah
One ways were designed for off throttle cornering. Compairing with all the other types (diff, spool, etc), the big thing you will lack is breaking distance. You will need measurably more braking distance to slow the car down compaired to what the other two would need for the same speed.
Carpet tracks are usually short enough that when a one way is used you end up fighting the braking distance problem more than anything you gain on turn in. You may be able to turn under the guy in the first turn, but in any sharp "s" turn, he will be able to carry more more speed into the late part of the second turn and usually pull ahead. Simply because you had to let off the throttle to make the other tight corner and get the inside lane again, and he was throttle on the whole time.
wcoyote is offline
Old 10-18-2004, 11:51 AM
  #1258
TLRacing
Todd Hodge's Avatar
Hey guys...sorry I have not been around....I have been getting ready for the Hurricane World Championships in Florida.
Todd Hodge is offline
Old 10-18-2004, 11:58 AM
  #1259
DavidAlford's Avatar
Trader Rating: 31 (100%+)
LOL
DavidAlford is offline
Old 10-18-2004, 03:47 PM
  #1260
Juan Valdez's Avatar
JRXS
Hey Todd,
Got to see the new car at the show in Chicago this weekend. It's sweet! You guys did a great job. There were so many cool little features that caught my eye that I forgot to look at some of the things I wanted to check out. Can't wait to get my hands on one. I had a question though. On the Losi website it says "Center spool and one-way options." Does the kit come with both in the box? I'm just curious as I was suprised to find a center one-way on the show car. I had not heard anyone talk about that before. If both the one-way and spool center shaft are include, that would be great. If not, will a spool shaft be an option? Good luck to all the Losi guys at Worlds! It looks like you have the car win.
Juan Valdez is offline
