Ask Todd Hodge..aka "Hodgimoto"
#1051
Thanks Todd, I got the setup and it looks great, can't wait to try it
#1053
Well Todd I've had a fair amount of time with the car now. I installed the 12 Turn still have the 7 cell. Wore down the battery side tires well (extra cell weight me thinks?). I'm currenly have the shocks lengthened one and a half turns. roll bars front and rear (second largest on the back and second smallest on the front). Stock otherwise. Turn in seems good. I'm running on regular road (bumpy), so if you have any ideas for me I would appreciate it. I'm wondering more about shock settings/different springs to use.
#1055
first rcgod, there is a reason they dont use a one way its not faster.
Also todd, is there any downsides to milling out a chassie for running on high bite carpet? I really like the way it looks and the weight reduction.
Also, what are the handeling differneces in a setup like bobby flack used at the novak race last year, as opposed to your snowbirds setup from the year before? I have been told your setups are faily easy to drive Im just looking for some type of comparision.
#1056
if you mill it all the way through you will get a bunch of carpet crap in your diffs and drive train parts, also if you take off way to much you will have chassis flex, which as you should know, on carpet is not a good thing.
And to answer the one way question, it is the same as running a spool on capret, there is way too much traction and you will break parts if you hit anything, you would be busting one way outdrives like a egg on crack, and diffs are faster anyway, unless you are on asphalt in which case you would run a steel/aluminum/composite spool. I hope this answers all the questions, now for one of my own.
Todd, I want to run the black belt in 19 turn pretty loose on carpet with 2 diffs and the stock bearings (degreased with one sheild off) would you think that the belt would skip if you cut every other tooth off? And also, I can't believe that Losi let the white ball cups out to the public, I can't wait to see what the team drivers will have to make their cars that much different. I won't be running the white ball cups because now everybody will have them.
Thanks Todd, check you later
#1057
Todd - No rain yet but will will get a little bit on Sunday and Monday...
Barbequing on Laborday for fun is one thing but barbequing on Laborday because you have no power is something else entirely. Hopefully the storm will go north of us as predicted. If that happens we will tons of rain and some heavy winds...not too bad though.
Of course its not so good for those in the direct path of the storm. This one will flatten wood frame houses and tear the roof off cinder block houses. I hope everyone listens to their local authorities and gets to a shelter if they are told to do so....this one is no joke.
#1058
tc3stocker: You need to change your handle!!!! LOL. I doubt you will have any problems with the belt skipping, even if you remove teeth. I have the teeth on my belt cut and it hasn't skipped at ALL, not in with a 19t or with an 8t. I know you want to run your belt loose to keep your drive train free- but beware of other things, too, ie carpet fibers in you stub axles or CVD.
As for the ball cups, the newer white ones included with the MF2 kit are actually a new design, too, not just white. They have been 'released to the public' because of so many reuqests from the racers.
#1059
Flipover- Hey what tires (not just Losi ones, lol) were working at the badlands when you were there last spring. Regionals at the end of the month. If you want just PM me, hate to tie up Todd's thread for non Todd discussion, hehe. I lost Travis' email.
#1060
tc3stocker, thank you for the detailed answer on the one-way. I'm new to carpet racing, and I couldn't figure out how a one-way wouldn't be faster since that's the hot setup when running nitro on foams. Now I can save the $60 I was going to spend on the one-way and buy more tires.
#1061
#1062
TL-XXXS-Its all practice!!
Richo-Cool.
wcoyote-Maybe stiffer springs to support the 7 cell???
rcgod-We have found that diffs are faster on carpet all the time. So I really do not have any setups. I think if you do try a oneway you will see that it pushes slightly going in and is really hard to drive when you pick up the throttle. Just try a really tight front diff. That will be the ticket.
pballkid-I think that lightening the chassis can only help. As for the setups...I have never tried Bobby's setups however I know his setup is very fast in stock..not sure in mod. Yes generally my setups are a bit easy to drive. I may loose a tenth but I gain it back in consistency.
tc3stocker-You will be OK with the belt in 19t. I ran it that way in mod
Bradon-No problem
Adrian-Well be safe this weekend. I wish everyone the best this weekend. I really don't know how you live in FL. Those hurricanes would be a little frustrating to deal with!
Richo-Cool.
Bradon-No problem
#1063
Todd - Well... you might be living on an island off the coast of California in a few years....lol! How can you live in Southern California?
The answer is because you dont have earthquakes everyday. We may have a storm blow through every couple of years but the damage is usually pretty minimal. However, just like California we get a big one once in a while. At lease we get a few days of warning to get out of the way.
