Ask Todd Hodge..aka "Hodgimoto" >
Old 08-27-2004, 02:24 PM
  #1036
The Evicerator
A silent Barry is it's own reward!
Steve Weiss is offline
Old 08-27-2004, 03:20 PM
  #1037
Last year at the triple crown races I watched the factory drivers run their cars through tech and everyone of them came in almost exactly at legal weight. Losi guys were all running factory chassis' except Kinwald. How do you guys do that? My xxxs is a fat pig.
JimMcClure is offline
Old 08-27-2004, 03:24 PM
  #1038
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
One thing you have to be carefull of is body weight.
Jon Kerr is offline
Old 08-27-2004, 03:35 PM
  #1039
J.Filipow's Avatar
Trader Rating: 15 (100%+)
Graphite, aluminum, and titanium components result weight reduction.
J.Filipow is offline
Old 08-27-2004, 03:37 PM
  #1040
AdrianM's Avatar
Thats and some judicious use of a Dremel tool on the chassis...lol!
AdrianM is offline
Old 08-27-2004, 03:44 PM
  #1041
The Evicerator
Did you know that alot of dremel tools are used in brain surgery as a means to cut through the skull to gain access to the brain and spine?
Watch out! Anyone with the right dremel tools might try to perform brain surgery on you!
Old 08-27-2004, 03:59 PM
  #1042
AdrianM's Avatar
AdrianM is offline
Old 08-27-2004, 04:00 PM
  #1043
Jon Kerr's Avatar
Steve, step away from the Dremel.
Jon Kerr is offline
Old 08-27-2004, 06:43 PM
  #1044
J.Filipow's Avatar
WHOA!! It's Todd.....
Old 08-27-2004, 08:30 PM
  #1045
Still Bill's Avatar
Trader Rating: 16 (100%+)
Wink
The car's body weight or the driver's???
Still Bill is offline
Old 08-28-2004, 12:31 AM
  #1046
I think the cutting tools used in brain sugery are powered by compress air.
caveman is offline
Old 08-28-2004, 08:28 AM
  #1047
tc3stocker's Avatar
hey Todd and all posters, I need a setup for onroad asphalt outdoor with rubber tires, for a 19t car with a one way, this is on an open track, thanks
tc3stocker is offline
Old 08-28-2004, 08:36 AM
  #1048
TLRacing
Todd Hodge's Avatar
mtc30d-You know...I think I used...the profile that had the lowest drive frequency.
JimMcClure-Aluminum screws, titanium hinge pins, no battery strap(tape your batteries in), no rear bumper(just use a small piece of lexan on the bottom to cover the pulley), titanium shock mounts, and thats about it.
Adrian-Got Rain??
tc3stocker-Check out my Socal Raceway thread on www.teamlosi.com.
Todd Hodge is offline
Old 08-28-2004, 08:52 AM
  #1049
TL_XXX-S_racer's Avatar
Hey todd how do I make my XXX-S be smooth and consistant on the track. I see all the pro guys cars so smooth and stick so well. How can i do that? If your AIM can i IM you?
thanks for your help.
TL_XXX-S_racer is offline
Old 08-28-2004, 11:27 AM
  #1050
RichO's Avatar
Todd: I messed around with that underdrive setup at Fernando's a few weeks back. I found it a little stuck in the corners and pushing on the big sweepers. We did sugar water the track in the morning, but it was humid and not many people running. I made a few changes that perhaps may be of interest:
Front Shock: 4
Rear Shock: 3
Front Camber link: 3
It works very good in the wacky dog leg at the end of a sweeper and seems really balanced through-out.
I am going to mess around with the droop and the camber link positions. I was using the 4 hole in the front and 6 hole in the rear with the non-overdrive setup with 50Wt oil in the front.
RichO is offline
