Ask Todd Hodge..aka "Hodgimoto" >
Old 08-21-2004, 12:01 PM
  #1021
SlobbaTech's Avatar
How's dat wheelie setup coming along? Not done yet, DAAANG man, when you get r done let me know so I can try it out at the local fuzz track.
SlobbaTech is offline
Old 08-21-2004, 04:36 PM
  #1022
TLRacing
Todd Hodge's Avatar
Pooky-No I have never tested them. I run NMB bearings. Black belt is worth the money. I think you will be amazed on how much it frees up the drivetrain.
jc510-Not sure where you are located however your LHS should be able to get your part on a special order.
BryanD-yes I run it outside all the time.
slobbatech-Its coming along kinda slow....some team driver orders takes days to put in the system since they are so big....lol!
Todd Hodge is offline
Old 08-21-2004, 08:42 PM
  #1023
SlobbaTech's Avatar
Aight man, haven't run my TC for like 2 years and sort of am getting tha itch for it again. So until you get that setup right I can't drop my car onto the track.
Old 08-23-2004, 11:11 AM
  #1024
Fatboy Joe's Avatar
Default Milled-Out chassis
Hi Todd,
I was wondering on the significant improvement or advantages of the milled out chassis compared to the stock G+ Chassis. What is the total weight of the car after it has gone through the diet? I'm about to start on the weight loss program for my G+ Thank you for your time
Fatboy Joe is offline
Old 08-23-2004, 11:49 AM
  #1025
J.Filipow's Avatar
Trader Rating: 15 (100%+)
Default Re: Milled-Out chassis
Originally posted by Fatboy Joe
Hi Todd,
Fatboy- My car, ready to run with rubber tires, comes in at about 47 oz. without the body. I have mine milled just a little more than Todd's.
J.Filipow is offline
Old 08-23-2004, 09:56 PM
  #1026
utracer's Avatar
hey Todd I heard you have a killer Spool set up I ahve never tried a spool want to try something new. maybe be the trend setter at my local track hahahaha anyway I run on a small track maybe 100x50 tight set up. would you sugest a spool for that kinda of track and where can I find your spool set up thanks for all the help Todd P.S. I am planning on trying to copy your milling job this weekend hopefully I won't kill the car
utracer is offline
Old 08-23-2004, 10:51 PM
  #1027
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Default Spool setup
Here's the setup Todd posted a coupld months ago.
Front Suspension
Front toe-0
Ride Height-4.5mm
Camber -1.5
Caster- 2
Kickup- 0
Droop-7mm(had 2.5mm of uptravel)
Front Pivot-2R(yes rear block on front to get straight front pins)
Arm Spacing-Middle
Ackerman-Forward and Flipped
Spool with 41t front pulley
.060 washers under bellcrank ballstud
Chrome ball stud with one gold washer on caster block
Camber Link- #3
Shock Position- #4
Team Losi Low Roll Center
Oil-60wt
Piston-#56
Spring-Green
Shock Length-60.5mm
REAR SUSPENSION
Toe In-2
Ride Height-5mm
Camber -1.5
Droop- 9mm of travel(4mm of travel)
Pivot-2R
Arm Spacing-Back
Camber Ball stud-Black
Camber Link 6/A
Shock Position- #4/Outside on arm
Roll Center-TL Low
Standard rear end
Oil-40wt
Piston-#56
Spring-Blue
Shock Length-65.4mm
Body-Mazda 6
Tire Additive-BG2
Jon Kerr is offline
Old 08-24-2004, 12:10 PM
  #1028
Fatboy Joe's Avatar
Default Re: Re: Milled-Out chassis
J.Filipow:Thanks for the info. That's pretty light. Was there any noticable performance gain?
Old 08-25-2004, 12:55 AM
  #1029
Hi Todd,
Can you help us out a little bit with the NMB Bearings? I visit the site but they are asking to many dimensions in order to find the bearings... Can you tell us the part numbers for the bearings that we need for the XXX-S. The bearings that you are running is shield or not?
Thanks for the help,
Harris
harris is offline
Old 08-27-2004, 09:34 AM
  #1030
TLRacing
Todd Hodge's Avatar
FatboyJoe-At the Nationals my car 2 oz under weight. I am really not sure if I saw a dramatic improvement in my cars handling when I put the super light chassis.
utracer-Some changes to the setup that Jkerr posted.
  #1031
TLRacing
Todd Hodge's Avatar
Old 08-27-2004, 09:36 AM
  #1032
TLRacing
Todd Hodge's Avatar
4 degree caster blocks
Std 0F block on the front
Rear link 3/a
harris-I will have to find that information out.
Old 08-27-2004, 09:37 AM
  #1033
Todd,
What settings did you or still use on the gt7 for stock touring car?
mtc3od is offline
Old 08-27-2004, 09:44 AM
  #1034
The Evicerator
Todd, you have been very active in your thread today! Congratulations! You have recieved The Woooop Woooop High Activity Recognition Reward for today! Along with the framable certificate, you also get a coupon good for one free scoop of ice cream from Swensons!
Steve Weiss is offline
Old 08-27-2004, 01:37 PM
  #1035
AdrianM's Avatar
Can you gave Barry an award for not posting on the Ask Barry Thread since last November?
Silent Barry is much more pleasant than talking Barry...
AdrianM is offline
