Old 07-22-2004, 05:42 AM   #901
TL_XXX-S_racer's Avatar
Send a message via AIM to TL_XXX-S_racer
Todd- On the XXX-S with the steering bell-cranks theres so much slop. Is there a way to take that slop out? I've heard that getting the aluminum bell-cranks will take the slop out. Is that true? My local hobby shop has the Matt Francis R/C red aluminum bell-cranks will those work just as good as the speedtech r/c aluminun bell-cranks?
What parts would you recomend from Matt Francis R/C?
thx
ProMatchRacing
"Nobody does it better"
Team Corally
Superior Hobbies
"Supplying all your r/c racing needs"
TL_XXX-S_racer is offline   Reply With Quote
Old 07-22-2004, 08:33 AM   #902
TLRacing
Todd Hodge's Avatar
TlRacer-Just replace the steel bushings and the bellcranks...that should tighten everything up. I never used the aluminum ones. I only run the MF front and rear pivots on my car.
Todd Hodge
Category Development Manager for Losi and Team Losi Racing
Losi and Team Losi Racing, brands of Horizon Hobby
Team Losi Racing, Orion, Nitrotane, Spektrum, Imagine It Graphics, Bradley Fine Line Designs, and Lunsford.
Todd Hodge is offline   Reply With Quote
Old 07-22-2004, 10:36 AM   #903
i replaced the the bushings with bearings. I also replaced the bell-cranks too.
ProMatchRacing
Team Corally
Superior Hobbies
Old 07-22-2004, 10:50 AM   #904
stumper1's Avatar
R/C Tech Charter Subscriber
Default Re: Graphite Conversion Kit Question
Originally posted by stumper1
Todd,
Does the Graphite Conversion Kit come with the current parts (G+ chassis, newer shock towers, off-set rear arms etc.)?
If so, dou you have the part#?
Deric
stumper1 is offline   Reply With Quote
Old 07-22-2004, 07:57 PM   #905
TLRacing
Todd Hodge's Avatar
stumper1-Sorry I past up your post. All current graphite conversion kits are packaged with the new chassis. So if you LHS has to order it then it will come with the new chassis, new shock tower and arms. All those parts were running changes in our molds.
TL-I am also talking about the shouldered bushings that the screws go through.
Todd Hodge
Old 07-22-2004, 08:24 PM   #906
I replaced all the bushing with ball bearings. every bearing u can put in the bellcranks instead of the bushings i put them in.
Well u already answered my question anyways.
thx.
What aluminum part would u recomend for the XXX-S. Should i get the low roll center aluminum pivot blocks? should i get the titanium turnbuckles what would you recomend to get. Between aluminum parts and titanium turnbuckles.
Thanks for all your help. and I'll see you at the Worlds in Florida.
ProMatchRacing
Team Corally
Superior Hobbies
Old 07-22-2004, 09:21 PM   #907
stumper1's Avatar
Todd,
Thanks!!
Deric
Old 07-26-2004, 10:54 AM   #908
imjonah's Avatar
Default Brakes and the novice driver
When you are learning how to drive, should you just ignore using the trigger to engage brakes. I simply let off the throttle to make the car slow down to negotiate turns. Baiscally going through the twisty part of the track it is less throttle before the corner more throttle after the turn, up and down never going all the way off or going past zero on the trigger and engaging brakes.
I find that either I have the throttle pulled all the way(on the straight aways or I move it back and forth in between 1/4 and 1/2 its full range. My controller has an exponetial function. Would it make sence to adjust that function to lower the actual amount of throttle I actually get for every moVe of the trigger, around the 0 point.
Do you have any advice in general about the seting up your transmitter, when you are just learning to drive. I have an Airtronics MX-3, and I have everything at the default/sero adjust point with the exception of Endpoint steering adjustment. I did limit how far the servo will move with wheel full over to right or left.
imjonah is offline   Reply With Quote
Old 07-26-2004, 11:46 AM   #909
Todd,
I've read through and see now what the change in the front hinge pin angles does. But what does changing the rear hinge pin angles do and why are they angled the opposite of the front. Thanks.
Brian
Brian Anthony is offline   Reply With Quote
Old 07-28-2004, 09:23 PM   #910
Todd,
When do you fly into Toronto ? I'm guessing Jeff is picking you guys up. See you guys on the weekend.
Chris Reilly is offline   Reply With Quote
Old 07-28-2004, 10:57 PM   #911
TLRacing
Todd Hodge's Avatar
TL Racer-Ti turnbuckles should be your first investment.
imjonah-I would definitely try using brakes as you are learning to drive.
Brian-The are angled that way so we have rear traction.
Chris-I get there tomorrow night...cya on Saturday.
Todd Hodge
Old 07-28-2004, 11:35 PM   #912
Send a message via AIM to bigoTC3fan Send a message via Yahoo to bigoTC3fan
Hi Todd
Hope you can help a fellow R/C racer i saw a while ago were you had talked about a differant type of thrust bearing you were using
can you please give me the name of the company and do they have the size for a TC3, or can someone tell me the size for the TC3
thanks for any and all help
Big O
HURRICANE MOTORSPORTS
TRACKSIDE
RacemR/C
B5 /Hobbywing /Futaba
bigoTC3fan is offline   Reply With Quote
Old 07-29-2004, 06:38 AM   #913
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
big o....mcmaster.com.... i dont have the size off hand, it is back a few pages on this thread though.....
Matt M. is offline   Reply With Quote
Old 07-29-2004, 12:29 PM   #914
mwcet8k's Avatar
Hi Todd, a couple of questions when you have a chance. When is Losi going to start selling the shortened sedan version of the new white ball cups?
Also, I noticed in one of the mags that you were running the Mazda 6 at the Reedy race. How does it compare to the Alfa? Which one have you settled on now that you've used both?
Thanks again. As always, I really appreciate all the help.
mwcet8k is offline   Reply With Quote
Old 07-29-2004, 10:35 PM   #915
RichO's Avatar
Todd (or Anyone):
Do you know the part number for the stub axle (CVD) alone for the XXX-S. I cannot seem to find it on any of the exploded diagrams without buying the main axle part as well.
Thanks,
Rich
RichO is offline   Reply With Quote
HAPPY BIRTHDAY TO TODD HODGE Still Bill Electric On-Road 23 04-22-2008 07:40 AM
Todd Hodge goes Live!!!!! Kropy Electric On-Road 71 06-01-2007 01:29 PM
HAPPY BIRTHDAY TODD HODGE Still Bill Electric On-Road 49 04-23-2007 02:38 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
