Ask Todd Hodge..aka "Hodgimoto"
#736
Originally posted by Bryan D
Todd, I used to use the droop screws but they are not up to much on my g+, can you suggest what shock length to run and inside and outside limiters to set the droop that way for 3mm front and 5mm rear.
The high or low roll center blocks and the angle of your inside pivot pins affects what thickness of spacer you use for the inside limiters. So Todd cannot respond with one pat answer.
If you have a Dremel tool with a thin cutting disk, you can cut the "O" shaped plastic spacers into a "C" shape. That way, you can easily place them on and off the shafts without having to take the piston off of the shock. That saves lots of time which Todd explained to me many posts ago.
Look at the Losi site for a setup close to yours for some hints on what spacers to use. Earlier, James Nguyen suggested .050/.060 as a starting point.
Bill
#737
Sorry, I use the low roll centres ft and rear and normall us 2r front and rear as well.
#738
Originally posted by SlobbaTech
You ever get that TC wheelie setup figured out yet? Looks like someone else has, got it from Novak Tray thread. White car in last frame.
http://www.rctech.net/forum/attachme...&postid=936856
So, I guess what needs to be done for more TC wheelies is to have me go to more races and get taken out in the main?
We'll have to work on this theory some more...
#739
Sundog1: We recommend starting out with a final drive ratio of 7.3:1 in touring cars... this will equate to a 32/128 gearing in the XXX-S
#740
For the rear, don't use any spacers. I had to unscrew the shock end about one turn to get 5 mm of droop.
Your shock position may affect this slightly, but on my car I have exactly 3 mm front, 5 mm rear with it setup like this.
#741
Originally posted by T. Hodge
PoppaRay-That is very unlikely that can happen. However if you want to send it back to me...I will gladly replace it for you. The sanding is done after they machine the cut outs on the bottom of the chassis to smooth any burrs off.
#743
todd:
one quick question, i was hearing that alot of people are cutting out every second tooth of the new black belt is that a good idea. and is it good for mod. please get back to me.
#745
Hey Todd,
Just wanted to thank you for being a very cool guy up at Speedworld on Friday, even as you were practicing.
It was pleasure meeting you.
Nick
Nick
#747
TEAM TROGDOR (you know)
also how was the "Mechanic in an Envelope" work out for ya!
#750
Originally posted by rocketron
any results posted from the race?
1. BK
2. MF
3. ____
19T
1. EJ Evans
Speedworld is good about posting results. Check www.speedworldraceway.com
