Ask Todd Hodge..aka "Hodgimoto" >
Old 05-25-2004, 01:39 PM
  #631
bballer's Avatar
Originally posted by T. Hodge
bballer-Well a spool will have less offpower steering than a diff but more forward drive. A diff will have less onpower steering since it will want to "diff" onpower. As for a spool on carpet with foam tires, I have not seen many people make it work and be real successful. It pushes going in then hold on...cause it has crazy onpower steering. Most prefer a diff on carpet. On asphalt you don't have near the traction so a spool can be used easily. Hope this helps you out.
thanks
bballer is offline
Old 05-26-2004, 08:15 PM
  #632
jaysimpson's Avatar
Todd has anyone tried the new diff spring from the BK2 in the sedan? I was wondering if it would be better in the XXXS since it is supposed to be better than the bevel washers and easier to set or will it even fit in that application.
Thanks!
Jay
jaysimpson is offline
Old 05-26-2004, 10:11 PM
  #633
SlobbaTech's Avatar
The spring doesn't fit in the XXX narrow diffs b/c the dogbone bottoms out, at least for off-road cars. For TC it might fit b/c there's less plunge but dunno for sure, you'd have to get the BK2 diff screw also b/c it's a good deal longer than the stock screw for the longer spring setup.
SlobbaTech is offline
Old 05-26-2004, 10:53 PM
  #634
TLRacing
Todd Hodge's Avatar
ldTony-Thanks!!
promatch-You have been Slobba'd on.....
slobbatech-Thanks for the info....good luck at the nats!!!
Todd Hodge is offline
  #635
TLRacing
Todd Hodge's Avatar
Default REEDY Race Car
Here are some pics of my ride for the Reedy Race.
Old 05-26-2004, 10:54 PM
  #636
TLRacing
Todd Hodge's Avatar
Default Top View
Top View
Old 05-26-2004, 10:55 PM
  #637
TLRacing
Todd Hodge's Avatar
Front View
Old 05-26-2004, 10:56 PM
  #638
TLRacing
Todd Hodge's Avatar
Rear View-Hopefully this is what all of the racers at the Reedy Race will be looking at
Old 05-26-2004, 11:02 PM
  #639
TLRacing
Todd Hodge's Avatar
Bottom
Old 05-26-2004, 11:05 PM
  #640
Hodgimoto - what kind of front shock tower is that? I see both you and MF and running tamiya shocks now, is that front tower needed to run them?
James Nguyen is offline
Old 05-26-2004, 11:07 PM
  #641
Trader Rating: 26 (100%+)
DDDDDDDDDDDDDDDDDIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIAA AAAAAAAAAAAAAAAAAAAALLLLLLLLLLLLLLLLLLLLLLLLLLLLLL EEEEEEEEEEEEEEEEEEEEEDDDDDDDDDDDDDDDDDDDDDD
Snoop would be proud of a G-ride like that. Later player - make'em all playa-hatas this weekend.
MDawson is offline
Old 05-26-2004, 11:11 PM
  #642
Trader Rating: 30 (100%+)
Man,second car that is running tamiya shocks and its not a tamiya.They are awsome to say the least.My Mi2 wears them proudly.
What pistons are you running in those shocks?Are you running losi pistons?
racenut123 is offline
Old 05-27-2004, 12:06 AM
  #643
mwcet8k's Avatar
Freakin' sweet Todd. Kick some a$$ man! Thanks again for all the help and advice.
mwcet8k is offline
Old 05-27-2004, 12:18 AM
  #644
Still Bill's Avatar
Trader Rating: 16 (100%+)
Now gotta think that Losi's next great hop-up for the XXX-S should be shocks.
Or a chassis that better supports the ESC in front of the motor.
Or carbon fiber shock mounts.
Or the 5th body mount post.
Thanks for the peeks Todd.
Still Bill is offline
Old 05-27-2004, 04:32 AM
  #645
racer-oZ's Avatar
Todd, I've been looking for the part number on the Tamiya shocks and have not found it, do you have one for us to avoid buying the wrong shocks?
racer-oZ
racer-oZ is offline
