Old 05-19-2004, 09:09 AM   #586
TLRacing
Todd Hodge's Avatar
mwcet-Yes trimming the rear wing down will give you more highspeed steering. Have you tried less antisquat or less toe in on the rear.
Todd Hodge
Category Development Manager for Losi and Team Losi Racing
Losi and Team Losi Racing, brands of Horizon Hobby
Team Losi Racing, Orion, Nitrotane, Spektrum, Imagine It Graphics, Bradley Fine Line Designs, and Lunsford.
Todd Hodge is offline   Reply With Quote
Old 05-19-2004, 01:23 PM   #587
EricF's Avatar
Default brown grease
What is brown grease? Is there a part number from Losi or is it something that you guys found locally?
Also, do you have a part number for the shims when running a spool?
AE 12R5.2 & R6(x2) - TC7.1 convert, F6 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 05-19-2004, 01:28 PM   #588
Default Re: brown grease
I believe the shim set part number is LOSA6230 and the brown grease is LOSA3012.
James Nguyen is offline   Reply With Quote
Old 05-19-2004, 01:30 PM   #589
Hey Todd,
Matt told me the new tan thrust grease is part number 3066, but that is the part number for the old white super sticky grease. Is the new tan grease a running change now?
James
Old 05-19-2004, 05:38 PM   #590
EricF's Avatar
Old 05-19-2004, 11:17 PM   #591
POOKYT's Avatar
Todd, This past weekend I raced the Oklahoma Inv. race in Tulsa. Me and my buddies had a blast! You should try to make it next year. Anyway, I tried to tun my spool in my G+. Actually I did run the spool but I went through 3 sets of diff halfs during practice. How can I get my spool to have some kind of life span to it? In all 3 cases where I busted the outdrives I had just barely grazed the wall. Am I just doing something wrong or what? YEA..YEA..YEA..I know just don't hit anything but that is unrealistic in a first turn pile or some light racing contact. HELP!
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 05-20-2004, 03:50 AM   #592
Todd,
When I use the inside shocks limiters to adjust droop, I end up with a preload on all springs (to achieve the 5mm ride weight).
Several drivers told me that's bad, a TC spring must never be preloaded !
What is your insight, have or not have preload? And if it's bad what's the best way, with the inside limiters, to adjust droop?
Thank's.
gearless is offline   Reply With Quote
Old 05-20-2004, 06:18 AM   #593
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Try metal outdrives, or if your gonna use plastic then try the ring that comes with the oneway.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 05-20-2004, 07:51 AM   #594
RichO's Avatar
So the next logical question is if you use the metal outdrives, what do you wreck then? The CVD's?
I remember going through a number of CVD's in my gas car when using a spool and tapping a wall.
Is there anyway to build something close to a spool but with SOME give for those of us "less than perfect people"?
RichO is offline   Reply With Quote
Old 05-20-2004, 08:25 AM   #595
TLRacing
Todd Hodge's Avatar
Fike-James has the numbers in his post.
pookyt-you can get the trinity outdrive savers. They help a lot with that. I personally groove mine and then use the oneway rings.
gearless-Hmmm....how much limiting are you running? I have been running 2mm droop in the front and 5mm in the rear and have not had my springs preloaded too much. Some preload is ok....they do not have to float on the shock with full shock extension.
RichO-Our cvd's are large enough in diameter that they will not break. I personally would just use the trinity outdrive savers on the plastic outdrives. They will never break.
TK1801 Blue Aluminum Outdrive Saver (2 pcs) Team Kinwald- Losi XX and XXX all models- blue aluminum outdrive saver. Fits over stock plastic outdrives. Strengthens out drives. Prevents breaking of out drives and increases their life.
Todd Hodge
Old 05-20-2004, 08:26 AM   #596
TLRacing
Todd Hodge's Avatar
If you guys do decide to use the outdrive savers make sure once you put them on that the dogbone pin does not bind up in the outdrive. It has to be free.
Todd Hodge
Old 05-20-2004, 07:38 PM   #597
Th-whats up dude? Long time no talk. It's Mac from SRS. What is going to be your starting set-up for RTROC?
Mac Mitchell is offline   Reply With Quote
Old 05-20-2004, 09:05 PM   #598
POOKYT's Avatar
thanks Todd and David et all. Guess I need to buy some blue sleeves now.
Todd I think when Richo was talking about CVD's the only breakage I have ever encountered has been with my Aluminum ones where the pin hole elongates and will break. My fronts always wear faster then the rears.
Brant
Old 05-20-2004, 09:57 PM   #599
TLRacing
Todd Hodge's Avatar
Mac-Sup man.. Here is what I will be starting with.
Spool Setup
Front Suspension
Toe Out-1
Ride Height-5mm
Camber- -1.0
Kickup- 0
Carrier- 4
Sway Bar- .070
Droop- 3mm
Pivot- 2F
Arm Spacing- Middle
Ackerman- Forward and Flipped
Front Drive- Plastic Spool
Drive-42F/42R
Shock Position- #4
Camber Position- Up and In between #2 and #3. Makes a perfect triangle
Camber Ballstud- Chrome
Roll Center- TL Low
Oil-70wt
Piston-#56
Spring-Purple
Rear Suspension
Toe In- 2.5
Ride Height- 5mm
Camber- -1
Droop- 4mm
Pivot- 2R
Sway Bar- .050
Arm Spacing- Back
Camber Ball Stud- Black
Rear End-Standard
Camber Link- 3/A or 7/A(7 seems to have carry a more consistent arc onpower)
Shock Position-#2/Outside on arm
Roll Center- TL Low
Oil-40wt
Piston-#56
Spring-Green
Tires-CS27 Premounts
Battery Forward
Tire Additive-Trinity Tire Tweak
ESC mounted in front of motor
PookyT-yea....your probably right on that one
Todd Hodge
Old 05-20-2004, 10:01 PM   #600
You ever get a chance to look at the one me and Brian sent you?
HAPPY BIRTHDAY TO TODD HODGE Still Bill Electric On-Road 23 04-22-2008 07:40 AM
Todd Hodge goes Live!!!!! Kropy Electric On-Road 71 06-01-2007 01:29 PM
HAPPY BIRTHDAY TODD HODGE Still Bill Electric On-Road 49 04-23-2007 02:38 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
