Ask Todd Hodge..aka "Hodgimoto" >
Old 04-08-2004, 08:30 PM
  #436
TLRacing
Todd Hodge's Avatar
Gary-Just take a rear foam and cut 1/4 off of it and then bevel the inside edges.
wcoyote
Todd Hodge is offline
Old 04-08-2004, 09:25 PM
  #437
Still Bill's Avatar
Trader Rating: 16 (100%+)
Originally posted by wcoyote
Cool!
Thanks Todd for that bit of info. I never would have thought about the soda..
wcoyote,
Important thing about the soda is to let it dry after applying. Depending on the outdoor temp, that takes awhile. If you run on it wet, you will end up with your car covered in escargot slime.
My closest outdoor track uses regular root beer (not diet) for best results...Get a large bottle or two, shake it up and spray while walking the course. If you setup a defined course, be more concerned about spraying the turns as opposed to the straights.
Still Bill is offline
Old 04-09-2004, 10:22 AM
  #438
I'll get escargoo if it's not dried eh? I'm keeping notes on this. I wonder why Reg rootbeer works better than diet? Maybe it's the calories? Besides I never do unleaded soda.
I have plenty of Pepsi for the moment.
Taxes are back now. Maybe I'll get that car sooner than thought. I'm also thinking of helping out at Tekin if I can. Got to talk to Jim on that again. We shall see.
wcoyote is offline
Old 04-09-2004, 10:32 AM
  #439
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Regular soda has sugar in it. The sugar is what make it nice and sticky. I've seen some nasty mixtures including pancake syrup mixed with water, grape soda and sno-cone syrup mixture (Fred Hubbard special) as well as just straight rootbeer.
Jon Kerr is offline
Old 04-09-2004, 11:34 AM
  #440
R/C Tech Founder
I used Mountain Dew as a traction additive at the on-road series I put on out here last summer. I picked up a big walk-behind blower (a.k.a. Billy Goat Blower) and used it to clean off the surface beforehand, then used garden sprayers filled with Dew and laid it down in the run line. It worked very well.
futureal is offline
Old 04-09-2004, 11:46 AM
  #441
RCGaryK's Avatar
I'll try that Todd. I might run the car next week, as I will hopefully be retrofitting my carpet cars with front diffs and putting a Tamiya Track setup on them, so to race It'll have to be off road
Shane, you could even try the huge jugs (I said jugs, lol) of Syrup from Pick 'N' Save's Super saver isle. Do like a 1part syrup to 10 parts water and you should have Aunt Jamiama Quality traction
RCGaryK is offline
Old 04-11-2004, 12:15 AM
  #442
Hey Todd,
Could you comment on when and when not to use uptravel limiters and how they effect the losi car? Are you coming to the Speedworld Cup again this year? The flyers are up on the speedworld website .
James Nguyen is offline
Old 04-11-2004, 12:18 AM
  #443
The Evicerator
Hmm...someone didn't race tonight
Steve Weiss is offline
Old 04-11-2004, 12:37 AM
  #444
todd,
do you happen to have a setup for an xxx4 on a clay track, semi loomey with some medium-large jumps, also do you run a one way in ur xxx4 and why? would it help on a clay track with medium large jumps thats preatty smooth
Kave is offline
Old 04-11-2004, 09:10 AM
  #445
TLRacing
Todd Hodge's Avatar
James-I would recommend using uptravel limiters whenever your car feels like it wants to roll over too much. This is mainly on high bite tracks. You also have to be careful running uptravel limiters on tracks that have a lot of dots....since you can bottom the suspension out easier when running over them. I definitely plan on being at the SW Cup.
Evicerator-Sorry dude...I blew out
pball-Try Ryan's setup from the TL website....I think it works great everywhere. http://www.teamlosi.com/setups/xxx4g+/index.htm
I always run a oneway in my 4wd. It gives a lot more accelleration out of the turn.
Old 04-11-2004, 09:22 AM
  #446
STLNLST's Avatar
Trader Rating: 30 (100%+)
That's good to know since a couple of racers were using limiters yesterday. The traction was even close to being high bite but Matt F. even said that a couple of cars that he was watching could benefit from limiters. See you at the cup.
STLNLST is offline
Old 04-11-2004, 10:01 AM
  #447
Jon Kerr's Avatar
Hey Todd- Did you run a diff or a spool at Reedy Last year? I remember you mentioning once that you didn't like them but I wasen't sure if you ran one there or not. I was thinking, if I get in this year, of running just a fairly tight front diff, not an actual spool. I ran a spool last year and the car just didn't seem to have enough turn in for me.
Jon Kerr is offline
Old 04-11-2004, 10:15 AM
  #448
rice's Avatar
todd,
hi bro wanna ask what pinion am i gonna used in a d5 8x1 motor?
im using a 90 or 88 spur gear. what is my final drive ratio?
our local track is a combination of high speed and a little technical.
rice is offline
Old 04-11-2004, 12:25 PM
  #449
The Evicerator
It's ok dude, I understand... it was a tough day down there anyways... TONS of ppl on the driver's stand the whole day
Got my car better...I'll have to talk with you about it later I guess...
Anyways, have a Happy Easter!
Old 04-11-2004, 05:18 PM
  #450
jkerr,
I know reg soda has more sugar in it. I was joking about the calorie thing. Reg soda also has more calories in it because of the sugar content. Guess it was a different way of asking if the higher sugar was the cause.
wcoyote is offline
