Ask Todd Hodge..aka "Hodgimoto" >
Old 03-16-2004, 11:27 PM
  #361
Shanaynay?
James Nguyen is offline
Old 03-17-2004, 06:35 AM
  #362
hi james.
Sorry to have confused you. In the beginning the car was understeering, from entering corner all the way to mid corner.
I then decided to move the esc in between the motor and servo.
After that change, the car is spinning out instantaneously at almost all corners.
Now i need some help in setup, (with the esc at the front) or should i move it back again to the original position. Hope this clears everything out.
lozi is offline
Old 03-17-2004, 07:18 AM
  #363
STLNLST's Avatar
Trader Rating: 30 (100%+)
Originally posted by XXX-S Bill
STLNLST,
By what I just saw on RCRacing.com, you won't be welcome at Stockton until 2014 when you get off probation.
Gotta think of a caption for that picture...More to come (from others) for sure.
Lil Alex is 18 now so I'm safe.....lol I didn't win the event but I'll be remembered as the guy that made everyone laugh
STLNLST is offline
  #364
STLNLST's Avatar
Originally posted by James Nguyen
Shanaynay?
that's my code name.....shhhhhhhhhhhhhhhhhh!
STLNLST is offline
Old 03-17-2004, 08:40 AM
  #365
TLRacing
Todd Hodge's Avatar
lozi-Did you re-tweak your car when you moved the ESC? I have never had the car want to spin out like that before....are you sure you didn't change something else??
Ozwald-I have never ran foam tires on my elec. TC on asphalt. On my reflex I ran tan rear with Front only purples.
Todd Hodge is offline
Old 03-17-2004, 10:10 AM
  #366
Originally posted by lozi
hi james.
I would try to retweak your car then. Sounds like it is out of tweak from moving the weight around.
Old 03-18-2004, 08:32 PM
  #367
Todd what causes double steer and how do I get rid of it?
Asphalt
cs27
Losi alpha
battery forward
FRONT
green spring 50wt 56 piston 3 hole
2 deg kick up 4deg blocks mid roll center arms full back
std ball on carrier prp tower hole between 2&3 1 deg camber
bell crank back not flipped no washers
BACK
blue spring 50 wt 54 piston 2 hole on tower outside hole on arm
0 deg squat low roll center arms full back
std ball in A 0 deg offset hub 1 hole on tower 1 deg camber
Poppa Ray is offline
Old 03-18-2004, 08:54 PM
  #368
Todd,
Its been awhile.....hope all is well. See ya at SoCal......LC
Graphitedust is offline
Old 03-19-2004, 10:50 AM
  #369
TLRacing
Todd Hodge's Avatar
popparay-Try raising your rear roll center up .020 and then run the 4R block in the HRC holes. This should help get the car to initiate the turn better and take away some of that double steer. You can also try going to a #56 piston in the front so the front end can roll more.
graphitedust-Sup....CYA at Socal in April. I plan on running down there again ALOT!!!
Old 03-21-2004, 08:06 PM
  #370
cartmen34's Avatar
Todd, I 've got a ? for you. How do you measure droop? I've been reading the setup guide on the team losi site for the xxx-s and one thing does not make sense to me...which is the setting of the droop. How exactly are we supposed to use that droop gauge supplied with the xxx-s? Can you list the exact steps you go through to set the droop and ride height of your cars? Do you follow the exact steps as outlined on the team losi site?
The reason I ask is because it seems to me the numbers are backwards, with the 8 on the gauge being the highest, and 1 being the lowest....but this is backwards, because the setting of 8 on the gauge actually gives me the least amount of actual droop, and the 1 setting gives me the most amount of actual droop!! Why would we want to measure something like that? It doesn't make any sense to me at all. Please help me understand this messed up method of measurement!
thank you very much!
cartmen34 is offline
Old 03-21-2004, 10:46 PM
  #371
Registered User
Thumbs up
Can you post the set-up for your XXX-S from Rain City please?
JoeCathey is offline
Old 03-22-2004, 06:46 AM
  #372
TLRacing
Todd Hodge's Avatar
cartmen-I set my ride height first. I then pull up on the chassis as it is sitting at ride height to check uptravel that my car has. I then slide a ride height gauge under the car to see how much travel my car has. If it has to much or to little I will then take the tires off and adjust the droop accordingly. I use the droop gauge to make sure each side is even.
JoeCathey-Here is the setup that I ran
Front
Toe Out- 2
Ride Ht- 5mm
Camber- -1.25
Caster- 6
Kick- -2
Sway Bar- .080
Droop- 2mm
Pivot - 0F
Arm Spacing- Forward plus another .060
Ackerman- Forward and Flipped
Camber Ball Stud- Chrome with no washer
Overdrive- 41F pulley
No washers on spindle or bellcrank ball studs
Shock Position- #2
Camber Position- #4(up and in between #2/#3)
Shock Oil- 40wt
Piston-57 Std.
Spring-Trinity Purple
Limiter Inside- .060 Outside .200
TL Low roll center blocks
Rear
Toe In- 1.5
Ride ht - 5mm
Camber- -1
Sway Bar- .050
Droop- 3mm
Pivot- OR
Arm Spacing- Back
Camber Ball Stud- Ti Ballstud with .020 washer
Camber Link- 1/A
Shock Position- #3/Outside
Offset hub
TL Low roll center
Oil- 60 wt
Piston- #54
Spring- Trinity Blue
Limiter- .100 on outside. I am not sure on my internal limiting.....030 or .060
TiresF/R- Cyan 57.5mm/Magenta57.8mm with front outer glued
PF Alfa with no wing dams. Gear 128/26
Old 03-22-2004, 07:03 AM
  #373
CypressMidWest's Avatar
See you Wednesday, Sensei Hodgimoto.
CypressMidWest is offline
Old 03-22-2004, 07:45 AM
  #374
cartmen34's Avatar
So let's say you have 5mm of ride height, and 3mm of droop. That means that, when you pull up on the chassis as it is sitting at ride height and you slide the gauge under your car, you would get a reading of 8mm, correct?
I ask only so that I'm perfectly clear on how you do it.... and thank you very much for taking the time to answer my questions!
Old 03-22-2004, 11:35 AM
  #375
TLRacing
Todd Hodge's Avatar
cartmen-Thats exactly it.
