Ask Todd Hodge..aka "Hodgimoto"
#256
Ok can Todd or somebody help me out please? If this has been asked and answered, then I apologize, but I can't find it, so I'll ask. I'm taking a good look at the cars from snowbirds, and I run across this pic:
http://rctech.net/events/snowbirds20...ar_hodge_2.jpg
Now, this clearly shows what APPEARS to be a one-way....in the rear....hmm. Or is this just the normal plastic outdrives you've modified so that you can run the outdrive rings? I would have to assume that you've just modified the stock ones........right? If so, did you machine them, or just dremel a groove into stock outdrive?
Also, again, probably asked and answered, but how do you keep those little bearings on the pins of the driveshafts? 'Cause it looks to me like those would just fly right out of there without something to hold them in...no?
thanks for taking the time to answer.
#257
I can answer the first and speculate on the second.
those are called BK bones and will be out soon. the outdrives are widened to accept the bearings. I believe, correct me if i'm wrong, that the bearings are flanged so that they stay on.
hope that helps
hope that helps
#258
Todd, do you sand your diff rings? I'm assuming this helps with slipping while still maintaining a loose diff?
#259
#260
thanks james and racefan. I didn't really think I one-way would work in the back, but I just wanted to see what was going on there.
One more question. I've noticed that most factory cars have machined, blue, locking hex adapters. Are these adapted from another car? Or is this something else that will be available soon from teamlosi/BK?
Thanks again for all the answers.
#261
They are probably the AE clamping tc3 hubs or the Yokomo clamping tc3 hubs. I have the yokomo tc3 ones on my car.
#262
Hello everyone,
Please forgive me for posting such a simple question but, can you give me a good starting setup for carpet? I have visited the Team Losi site but wasn't sure which one would be best to use. I am looking for something that is fairly forgiving and can help me get in the ballpark. Any help would be very much appreciated. Thanks for your time
E
E
#263
what kind of tires and track conditions?
#265
Tight track, pretty short straight. I run a Chameleon if it makes any difference. I am AMAZED at the quick reply!
E
E
#266
and yes I am a d*mb*ss, we run foams
E
E
#267
try the 2 r block in front
1* toe in
1* camber all around
55 piston in front
54 in rear
50 wt all around
2r in back as well
1* toe in
55 piston in front
54 in rear
50 wt all around
2r in back as well
#268
Thanks racefan...recommend any springs with that setup?
E
E
#269
orange in the front, black in the rear
I believe there are 2 oranges so make sure you get the harder one
#270
Todd,
Reflex 12:
Just wondering what putting the Damper tubes on Top instead of the bottom does? Thanks!!
Ortiz
Reflex 12:
Ortiz
