Ask Todd Hodge..aka "Hodgimoto" >
Old 02-18-2004, 12:45 PM
  #196
EddieO's Avatar
I have given up wondering why people do the things they do, especially in RC....
Later EddieO
EddieO is offline
  #197
pro3racer's Avatar
hes just foolin around, wants to do something cool, like say, i want to be able to flip my truck over on it's back, with torque alone, like that.
pro3racer is offline
Old 02-18-2004, 02:23 PM
  #198
Post Todd
I was at the lhs the other day and the "guys" there said it would be a year untill the BK Bones were released due to problems w/ developement!!! Please say it aint so. Maybe it's just me but I figure if most of the bugs weren't already worked out then we wouldn't see almost every losi sponsored driver running them at the birds!
Poppa Ray is offline
Old 02-18-2004, 07:25 PM
  #199
TLRacing
Todd Hodge's Avatar
Fike-I am starting with the setup that I left the snowbirds...Its posted on here.
PoppaRay-Hmmm....that guys must know more than me then...lol. There are no problems. We just have a million projects going on at TL and they are not a priority right now.
Todd Hodge is offline
Old 02-18-2004, 07:41 PM
  #200
Trader Rating: 16 (100%+)
Default Guru T. Hodge
Todd (and futureal),
I just noted you are only listed as a Tech Apprentice at this time.
Maybe futureal could do something about that....Like advance you to Mongo Tech Guru...he, he...
You've got my vote.
Still Bill is offline
Old 02-18-2004, 07:51 PM
  #201
pro3racer's Avatar
Mongo Tech guru, nice, lol hey todd, do you shave your losi low r/c's down, if so, how far?
Old 02-18-2004, 08:21 PM
  #202
mike_Webb's Avatar
Todd-
DO you by chance know the setup for Matt Francis down at Snowbirds? I want to try out all kinds of different setups and get a good base setup and then go from there.
Mike Webb
mike_Webb is offline
Old 02-18-2004, 10:51 PM
  #203
EddieO's Avatar
From the looks of the pics of matts car on the snowbirds coverage pages, he was using a lot of trinity option parts. You could probably get his setup really easy from him on tech talk, he has his own thread over there he posts on all the time.
Later EddieO
EddieO is offline
Old 02-19-2004, 06:45 AM
  #204
mike_Webb's Avatar
You mean I have to go over there to ask him ... Can't he come here hahahahahha
Just kidding... I actually went there last night looking for his thread and could not find it at all in the Electric stuff. I only looked up to page 3
Old 02-19-2004, 08:01 AM
  #205
TLRacing
Todd Hodge's Avatar
XXX-S Bill-Sweeeeet!
pro3racer-I never cut the fronts down. But I have cut the rear down .060" and then I run the 2R block to keep 0 degree of antisquat. I actually ran this at Cleveland and thought it was good. At the birds I took it off because my car was starting to double steer in the hair pins.
mikewebb-Email me at [email protected] and I will forward it onto you.
Old 02-19-2004, 08:04 AM
  #206
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Hey Todd, can you elaborate a little more on what you mean by double steer.
Jon Kerr is offline
Old 02-20-2004, 01:01 PM
  #207
lazyboy's Avatar
Todd Hodge,
i have a quick question i was setting ride height on my xxxs for foams and i was having problems even getting above 3mm ride hieght in front but, was able to get 4mm in the rear. while i was looking at the front end, i was thinking ok maybe 3mm will work up front so i start setting droop and i get screwed, the lowest up from was 4mm of droop in front and 5mm in the rear(this is with a .30 spacer in the shocks). maybe im doing some thing wrong, but not sure. if you have any ideas i would really apprecate it.
thanks lazyboy
lazyboy is offline
Old 02-20-2004, 01:06 PM
  #208
pro3racer's Avatar
yeah tood, elaborate. I like my car very twichy, and i like to jurk it around the corners, i think double steer may be good for me, if i think the meaning is right.
Old 02-20-2004, 01:52 PM
  #209
R/C Tech Founder
The problem with jerking it around corners is that you will scrub a bunch of speed off; you may not even realize it is happening. The smoother the cornering motion, the more speed you'll preserve. The change is subtle but it will show up in your lap times.
futureal is offline
Old 02-20-2004, 02:06 PM
  #210
pro3racer's Avatar
oh, i knew that, just in really really tight spots i jurk it. I'm smooth in sweepers, and entering corners off straights, but when the turns are tight, i like to use the throttle to help steer. Also, when there isn't room to cross the track, so i can round the corner nicely, i jurk it around the turn. But i still bring the car to the outside wall. Like on our main straight, i use up so much of the track, half my left side tires are off the carpet(pvc pushed back from other car).
