Ask Todd Hodge..aka "Hodgimoto" >
Old 02-16-2004, 12:32 PM
  #181
chicky03's Avatar
Hey Todd,
What did you notice or what did you acheive going to a #54 and 60 wt vs. what you normally run in the rear.
Thanks,
Paul
chicky03 is offline
Old 02-16-2004, 03:12 PM
  #182
Thumbs up Internal Limiter
I think you've already answered my question but I'll shoot anyway. Is the .060 limiter your recomended for overlimiting the shocks to achieve droop ala "Cutting Carpet..." in RC Car? If not what would be?
Poppa Ray is offline
Old 02-16-2004, 07:32 PM
  #183
Todd, is that an aftermarket mount plate you have on your losi?
ZER01 is offline
Old 02-16-2004, 08:03 PM
  #184
TLRacing
Todd Hodge's Avatar
RichO-I use the TL droop gauge.
chichky03-I thought the car had more offpower steering and felt to be quicker in chicanes.
PoppaRay-That is what it is exactly for.
proudwinner-Nope that is a Hodgimoto Special
Todd Hodge is offline
Old 02-16-2004, 08:07 PM
  #185
EddieO's Avatar
I asked that on a different thread(I think on TT)....I guess its just todd having some fun with a stock plate and a mill.......
Later EddieO
EddieO is offline
Old 02-16-2004, 08:08 PM
  #186
Very nice work!
ZER01 is offline
Old 02-16-2004, 08:43 PM
  #187
Originally posted by T. Hodge
EddieO-Those were actual black wheels we were running. It is something TRC had made for Cleveland. The material was suppose to be stiffer but it was the same. Also all 28mm wheels from TRC now have a different offset. Now you can run the TL hex and be wide enough. This is on the black and yellow wheel. On the 26mm and 30mm TRC yellow wheel there was less offset so you would run the AE hex to get your car to max width and also to help from not rubbing the shock ends.
Mr. Hodgimoto,
What is the offset on the new black 28 mm rims? Is the offset changing on the 26 and 30mm yellow rims? If it isn't what is the difference between the 2 differen offsets then? Thank you.
Brian
Brian Anthony is offline
Old 02-16-2004, 08:45 PM
  #188
EddieO's Avatar
The 28mm rims are YELLOW, not black. The black rims Todd was running was a prototype material that was supposedly a different compound of plastic.
Not clue on the offset, but from what I gather it allows the tires to be ran at the full 28mm without having to be cut down to prevent rubbing.
Later EddieO
EddieO is offline
Old 02-17-2004, 07:46 AM
  #189
Eddie Garrison's Avatar
Hodge - Power Forward !!!!....B-Ball.....Have you seen our lineup yet ???...Go the SnowBird thread and see....You, MF, Pretzel, Richard and Me....We even have our positions posted from Coach MF.......L8
-EG
Eddie Garrison is offline
Old 02-17-2004, 08:48 PM
  #190
TLRacing
Todd Hodge's Avatar
Brian-With the old yellow 26mm wheel you have to run AE hexes for clearance issues. On the new 28mm wheel you do not have to. You can run the std. TL width hex.
Old 02-18-2004, 11:40 AM
  #191
EricF's Avatar
Default SIGP @ CH setup?
Todd,
Are you still going to make it to SIGP in Tucson this coming week end?
Do you have a setup that you like at CH? If you do, could you post it please.
Eric
EricF is offline
Old 02-18-2004, 12:19 PM
  #192
Can you tell me how to make a xxx-s pop a wheelie or what setup changes I need to work on? Thanks bro!
rwjso is offline
Old 02-18-2004, 01:16 PM
  #193
R/C Tech Founder
A wheelie? Take out the front CVDs and put a 6 turn motor in it. But even then, it's probably not going to work. haha
futureal is offline
Old 02-18-2004, 01:20 PM
  #194
EddieO's Avatar
You would also have to increase suspension travel in the rear and REALLY soften it up. Then put a real stiff front shock setup on it.....ride height would have to be raise to prevent the chassis from bottoming out, but you would want the rear lower than the front, which you would want kinda jacked up. Put a killer motor in it, like 6 turns or so, with 10 cells.....and a REALLY small pinion. Use foam tires in the rear and put a crazy amount of traction compound on them, none in the front.....you might have to put additional weight in the rear and lighten up th front, but its doable.
Later EddieO
EddieO is offline
Old 02-18-2004, 01:33 PM
  #195
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Am I the only one whos wondering, WHY?
Jon Kerr is offline
