Ask Todd Hodge..aka "Hodgimoto"
#1726
Originally Posted by T. Hodge
I don't think so.
#1727
Well whatever you do good luck.. Call Danny hes aways looking for another A-Main Driver......
#1729
Originally Posted by P-DUB
Sup Hodge....Round brushes now
#1731
Hi Todd. Digging through your asphalt setup on the XXX-S G+; You said you start with blue springs in front. What about rear? And running the standard rear carrier position (not off-set) what drive shafts and other bits will I need? Thanks.
#1732
Todd,
Durka durka, Durka Sorex Durka RP? Durka Durka Buggy Grip II? Durka Tire Durka Tweak?
Durka!
Durka!
#1733
Originally Posted by Evicerator
Todd,
Durka!
Durka!
Brant
#1734
#1735
Todd,
Durka!
Durka!
LMAO
#1736
Originally Posted by Jack Smash
I'm petting a POINT will be made.
WOW....LOL....I will have to CHECK back and see if you are right!
#1737
Originally Posted by Tres
Todd: fyi package is on the way..
Got it yesterday....hurting....sorry about that....did you get what I sent to you?
#1738
Todd: I'm gonna be running 19 turn foam (if they offer it) at the up-comming Region 12 Carpet Championships at Hobbyworld Gilroy. Any advice?
I noticed the US Champs Setup and the ROAR Nats Setup are very similar. I found it a bit odd BK was using a .5 rear sway-bar and none up front. What do the .60 washers on the bellcrank plate & .90 on the knuckle do?
#1739
Dan 19 wont be foam, never has been.
#1740
I thought it was stated somewhere that if theres enough demand for foam classes they'd be ran. Not all of Region 12 are weirdos and run rubber tires on carpet
