Ask Todd Hodge..aka "Hodgimoto"
#1606
Originally posted by xxxkat
Todd,New carpet track in Ca. about 1 hr 20 min. north of bakersfield,
#1607
Major interests (for stock/asphalt) are:
Springs - Good selection? The car comes with 12.5 rear and 35lb front. For asphalt/carpet I would get 15-20lb for the rear. For the front I would get. 42-60lb. That should have you covered well
Pistons - Good selection?So far I have only liked the stock pistons in my setups.
Pivot mounts - Do I need all the different configurations?I would recommend just getting a extra 1 and 2 degree pivot.
Sway bar - Two sets of bars will give you two of .030, .040, .050, and .060.
Shock oil - 40wt-60wt
Front spindles and carriers - Good selection? 2-6 degrees
One-way - For what circumstances on asphalt? A oneway will be great on larger flowing tracks where brakes are not needed.
#1608
Since you guys did so much testing up at 4 Fun Hobbies and Raceway, how about giving us a headstart on set up. and how different will the setups be for stock and 19T. And what bodies should work best for the car as a starting point.
#1610
The car comes with 12.5 rear and 35lb front. For asphalt/carpet I would get 15-20lb for the rear. For the front I would get. 42-60lb. That should have you covered well.
* 15# LOSA5349
* 17.5# LOSA5350
* 20# LOSA5354
* 42.5# LOSA5355
* 50# LOSA5356
* 60# LOSA5357
* Sticking with that recommendation
* Aluminum 2 degree LOSA9685 (neg 2 is LOSA9681) Revised
* Aluminum 1 degree LOSA9684 (neg 1 is LOSA9682) Revised
Sway bar -
* F or R swaybars LOSA4252 (times 2)
Shock oil -
40wt-60wt
* Understood
* 2 degrees LOSA9755
* 4 degrees LOSA9757 (standard)
* 6 degrees LOSA9758
* Understood
* 15# LOSA5349
* 17.5# LOSA5350
* 20# LOSA5354
* 42.5# LOSA5355
* 50# LOSA5356
* 60# LOSA5357
Sway bar -
Shock oil -
40wt-60wt
* Understood
* Understood
#1611
To clarify.
Are those pluses (+) and/or negatives (-) for the pivot mounts?
Bill
#1612
Hodgimoto--The updates on the website look great....give us more!! I know you guys have been covered up around there but the updates on the website are very good for all of the newbies we have been getting around my area lately. Keep it up!
Brant
Brant
#1614
Hello Todd,
I was looking through some images on jrxs.net, and I came across an image of your prototype jrx-s at the Region 12 races. I noticed that you had two fans pointed at your motor....
I was wondering exactly what size are those fans, and where did you get them? I ask because I've been looking around locally, and the closest I can get is 4x4cm small computer fans from RadioShack. It would appear that yours are smaller, and I will have to order them online, so I want to be sure to get the right ones the first time!
Thanks for your help!
#1616
#1617
Originally posted by JRX-S Bill
Todd,
To clarify.
Bill
Todd,
To clarify.
Bill
#1618
Originally posted by cartmen34
Hello Todd,
Hello Todd,
#1619
Originally posted by Jon Kerr
Todge, Your car looked pretty strapped yesterday. Wish I had a better day so I could have run with ya.
