Ask Todd Hodge..aka "Hodgimoto" >
Old 03-24-2005, 09:53 PM
  #1591
Still Bill's Avatar
Trader Rating: 16 (100%+)
Originally posted by STLNLST
I have been using plugs since forever if I'm considered a fast guy. Dujuan also runs conectors.
Never suspected...But, you can drive too...he, he...
Still Bill is offline
Old 03-28-2005, 11:33 PM
  #1592
SRS
SRS's Avatar
Todd-What graphics company do you use for your face plates, setup boards, etc. Thanks dude.
SRS is offline
Old 03-29-2005, 08:14 AM
  #1593
TLRacing
Todd Hodge's Avatar
Right now I have Maxspeed designs on my equipment. However that will soon be changing to Vinyl Graphics Unlimited. Gary is going to start getting into the face plates, setup boards, ect. Right now he is working on a decal that would go over the Hudy board. The hudy board is great since it is light, cheap, and durable.
Todd Hodge is offline
Old 03-29-2005, 09:09 AM
  #1594
Trader Rating: 40 (100%+)
Hey Todd, I noticed the different degree pivots listed for the car, I assume these change the angle of the arms front and rear... is there an advantage to changing the arm angle over changing the toe in with the rear hub? Or is this actually for something different?
brians11 is offline
Old 03-29-2005, 09:17 AM
  #1595
Todd,
can i ask you what srings, swaybars, pistons, oil, caster blocks, rear hubs and anything else i should get, to get the new car setup for foams on carpet?
Thanks,
Scott
SPC Racer is offline
Old 03-29-2005, 04:35 PM
  #1596
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Todge- I noticed all the adds and such for the JRXS are sportin' your paint scheme. Does this mean it's going to be the JRXS Todd Hodge Edition
Jon Kerr is offline
Old 03-29-2005, 07:31 PM
  #1597
T. Hodge...is my hero, so hey how the special at the dinner place at the nats's..like bro,heard it was kindda iieekkkee...
FERNANDO is offline
Old 03-29-2005, 07:34 PM
  #1598
DENNIS STORTI's Avatar
Trader Rating: 42 (94%+)
HEY Nando
did u get my email
DENNIS STORTI is offline
Old 03-29-2005, 07:36 PM
  #1599
i talked to charlie today hes gonna set me uphey email me or hit me up on aol im i need some stuff
Old 03-29-2005, 07:37 PM
  #1600
xcaptainpunchx
Old 03-29-2005, 08:13 PM
  #1601
TLRacing
Todd Hodge's Avatar
LOL...yea I will get you guys back. I laughed my A$$ off with some of those letters.
Old 03-29-2005, 08:14 PM
  #1602
TLRacing
Todd Hodge's Avatar
Only in my dreams
Old 03-29-2005, 08:19 PM
  #1603
TLRacing
Todd Hodge's Avatar
Originally posted by SPC Racer
Todd,
Thanks,
Scott
We have been using 60lb springs in the front and 25lb in the rear. So I would say get a set of 50lb springs and a set of 20lb springs. That should cover you for a while. For caster I have been running the kit caster of 4 degrees. Pistons, I use the kit pistons. For sway bars, I have been using a rear bar to tune the steering in my car. The thicker the bar results in more steering. So just get one sway bar kit. For oil I have been running kit oil in the rear and 50wt in the front. The car comes with 40wt. For hubs, this really depends on what you want out of your car. If you like a really agressive steering car the offset 0 degree hubs will be the ticket. If you like a limo(like me) then you will want to stick with the kit hubs(0 degree standard). Email me at [email protected] and I will be happy to send you the setups a few of us have been running on carpet with foam tires.
Old 03-29-2005, 08:27 PM
  #1604
Oasis's Avatar
Trader Rating: 38 (100%+)
Todd,New carpet track in Ca. about 1 hr 20 min. north of bakersfield,
Oasis is offline
Old 03-29-2005, 09:04 PM
  #1605
Still Bill's Avatar
Todd,
Read what you said above.
Would you have a list of recommended parts to start with for the JRX-S for use in setting up the car for typical stock class racing on asphalt using rubber tires?
I already ordered f/r arms and a one-way. Have the different rear hubs. But, I'm not too sure about any other parts needed to change setups.
Major interests (for stock/asphalt) are:
Springs - Good selection?
Pistons - Good selection?
Pivot mounts - Do I need all the different configurations?
Sway bar -
Shock oil -
Front spindles and carriers - Good selection?
One-way - For what circumstances on asphalt?
Many thanks.
Bill
