Ask Todd Hodge..aka "Hodgimoto" >
Old 03-20-2005, 10:06 PM
  #1576
SCML's Avatar
It's not the plugs that are the problem, it's the extra solder joints. If you hardwire, you have solder at the esc, and at the battery. If you use plugs, you have solder on both ends of the plug, 2 times the solder joints, more resistance.
Mike
SCML is offline
Old 03-22-2005, 08:23 PM
  #1577
Still Bill's Avatar
Trader Rating: 16 (100%+)
Todd,
How did the Carpet Nationals go for you?
Can you detail once again which bearings sizes are required for the new JRX-S? I, and others, want to order ceramics.
Here was one response (from TCR) to the original question.
Bill I believe it's
8 - 3/16 x 3/8
4 - 5mm x 8mm
4 - 1/2 x 3/4
2 - 4mm x 8mm
4 more 5 x 8 if you want them for the steering rack
Many thanks.
Still Bill is offline
Old 03-23-2005, 07:50 AM
  #1578
TLRacing
Todd Hodge's Avatar
JRXS Bill-The race went ok. I ended up 6th qualifier and overall 8th in mod. In 19t I was 10th qualifier and 5th in the mains.
Bearings-4x8mm= 2, 3/16x3/8=8, 1/2x3/4=4, 5x8mm=8(both diffs and steering rack). For the steering rack and diffs I would not worry about those for ceramic. Those are mainly just support bearings and do not see much movement like the other bearings do.
Todd Hodge is offline
Old 03-23-2005, 07:55 AM
  #1579
Trader Rating: 40 (100%+)
Todd, can you tell us what springs will come in the kit? And what springs are you guys running on asphalt tracks as well?
brians11 is offline
Old 03-23-2005, 09:15 AM
  #1580
Regional Moderator
Darkseid's Avatar
If my memory serves me correctly, I think the kit springs were said to be 35 front and 12.5 rear.
Darkseid is offline
Old 03-23-2005, 06:34 PM
  #1581
now, will the ae springs fit? if the 10mm is the dia, then they wont... just confirming before i start ordering stuff
brians11 is offline
Old 03-23-2005, 07:31 PM
  #1582
Still Bill's Avatar
With the short arms on the JRX-S and the really different attachment points for the shocks, I would think that the spring rates required would be radically different from AE anyway.
Old 03-23-2005, 07:40 PM
  #1583
just wondering since they have springs down to 10#... they must have some of those for the rear end...
brians11 is offline
Old 03-23-2005, 09:45 PM
  #1584
Still Bill's Avatar
Todd,
This may be a bit more complex than the bearings; but, can you provide a list of all the screws required on the JRX-S?
Want to put together an order for titanium screws. Many thanks.
Bill
Old 03-23-2005, 10:59 PM
  #1585
TLRacing
Todd Hodge's Avatar
Like Darkside mentioned, they are 35lb front and 12.5 rear.
Old 03-23-2005, 11:05 PM
  #1586
TLRacing
Todd Hodge's Avatar
Originally posted by JRX-S Bill
Todd,
Bill
Wow...lets see if I can do this from the top of my head.
4-40x3/8" Flatheads=40
4/40x3/8" Capheads=14
4/40x1/2" Capheads=4
4/40x3/8" Buttonheads=10
That should be really close.
Old 03-23-2005, 11:11 PM
  #1587
Still Bill's Avatar
Todd,
Many thanks. You always come through.
Old 03-24-2005, 05:05 PM
  #1588
Bill My old Yokomo was a three wire. I used deans plugs on the motor and sermos plugs on the battery. Simply because I could route the negative and Positive wire separately. Worked good enough for me. I'll probably use that same setup again. I already got the connectors.
wcoyote is offline
Old 03-24-2005, 07:46 PM
  #1589
Still Bill's Avatar
This weekend is the first race in the NorCal Touring Car Championship Series. I'll watch for any of the fast guys in Stock, 19T or Mod are using any connectors as opposed to soldering. I expect to solder with my JRX-S as I already do with my 12th scale cars.
Old 03-24-2005, 09:37 PM
  #1590
STLNLST's Avatar
Trader Rating: 30 (100%+)
I have been using plugs since forever if I'm considered a fast guy. Dujuan also runs conectors.
STLNLST is offline
