Old 07-06-2009, 05:29 PM   #1
Vyger's Avatar
Questions?? Foam Tire Glue....HELP!!!!
OK, Iím hoping someone out there in the world wide interweb can help me. Back in the day (mid and late 90ís) I use to mount my own foam tires to the wheels. I use to have to coat the tire and the wheel separately, let them dry, then dunk them into lacquer thinner and slide them onto the wheel.
My problem is now that Iím getting back into this (a decade later) I want to mount up some foam tires, but canít seem to find the glue/adhesive at the LHS.
Does anyone have a suggestion on a good glue/adhesive or know of a shop that sells it? If you can suggest the name of the product and not just ďrubber cementĒ that would be niceÖbut at this point any help would be appreciated
Thanks,
Vyg
Tamiya Road Wizard, F101ís, F102ís, F103ís, F103RSís, F103LM, F103RXís, F103RMís, F201's, TRF-F103R, F104 PRO's, F104 F-60 & MP4-24, F104X1's F104 V2's, a TRF101 and a TRF101w...The King of Queens
Vyger is offline   Reply With Quote
Old 07-06-2009, 05:46 PM   #2
timmay70's Avatar
You are looking for contact cement. Your local hardware store, even wally world and the big K should have small cans with applicator tips (same can Jack used to come in - with the brush attached to the cap).
Apply to both sides, allow to dry, swab with lacquer thinner and slip together (quickly).
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 07-06-2009, 07:17 PM   #3
Trader Rating: 33 (100%+)
I think the old name was AJ's Black Magic Tire glue, it was black and came with a donut horn.
Chris Lockhart
**TEAM RCAMERICA**XRAY**HUDY**PROLEVEL RC**
chensleyrc1 is offline   Reply With Quote
Old 07-06-2009, 07:41 PM   #4
Weldons Contact cement I think in white cans (used to be).Who's got donuts(1/10th) at reasonable prices?
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT-12 Racing USA (21.5 ), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 07-06-2009, 08:24 PM   #5
Back in the real day, like 1980, we would use a product like 3M contact adhesive (Yellow Death), aka, weatherstrip adhesive. It worked OK, but failed frequently.
I used a product from Delta mfg. available in a pint can and occasionaly in a gallon size. This stuff simply worked great.
You might Delta and see if they will tell you what it was and then go buy it.
Good Luck
quickie is offline   Reply With Quote
Old 07-06-2009, 08:44 PM   #6
daygoVR6's Avatar
does parma/pse still make some stuff ? I remember them having something back in the day as I recall
daygoVR6 is offline   Reply With Quote
Old 07-06-2009, 09:32 PM   #7
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
As far as I know CA is used to mount tires now.
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 07-07-2009, 09:33 AM   #8
Vyger's Avatar
Thank you all for your replies. Iíll check my local hardware stores to see whatís available. I recently purchased a Tamiya F104 and I donít like using the kit supplied tired tape to mount up the tires.
Thank you again everyone!
Old 07-07-2009, 02:54 PM   #9
heavy's Avatar
Trader Rating: 20 (100%+)
You want Bear Contact Cement - or some other similar product
Look here
I personally use the one in the tube - coat the complete inside of the tyre and the complete outside of the wheel and leave till they are dry. Then paint with Mineral Turps (probably thinners would be the same) which makes them slippery and able to be worked into the correct position before the glue dries. They won't come off.
I've just rediscovered the art to this after 15 or so years as we started racing F1 again here in Brisbane, Australia. Good luck with it.
Honorary Life Member Logan RCCC -Mi6EVO and Serpent F1
Honorary Life Member Chargers RCCC -Cat K1 Aero
Life Member Bayside RCCC -Schumacher Mi6EVO
Boondall. SuperShot, XX, SVR,Schumacher Storm BigWig
heavy is offline   Reply With Quote
