Old 07-06-2009, 11:26 AM   #1
Trader Rating: 23 (100%+)
Send a message via Yahoo to JATOdriver
Default How to CA a C/F chassis?
how do you CA a carbon chassis, i see it done on the pics of all yalls cars and it looks nice and was wondering how yall go about doing this without getting brush strokes from brshing it on, thanks ahead of time for helping a newb to the road side of things
JATOdriver is offline   Reply With Quote
Old 07-06-2009, 11:35 AM   #2
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
I simply sand the edges so they are slightly rounded... then take my CA and place a few drops on the end of a Q-tip, and then carefully run the Qtip along the edge of the chassis. One end of the Q-tip can normally get 6 or 7 inches of chassis before it starts to dry. Move relativly quickly to keep the Q-tip from gluing to the chassis. You might end up using 5 or 6 Q-tips.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 07-06-2009, 12:09 PM   #3
thanks for the info, how do you make the top and bottom shinny as yall get em?
Old 07-06-2009, 12:38 PM   #4
Super Moderator
Example Picture? I don't know anybody that does anything to the tops/bottoms other than normal cleaning.
- RCSpecialties -
Old 07-06-2009, 12:40 PM   #5
2wdrive's Avatar
some polish there chasis before they assemble everything. I think they do it with car polish. 3M or something
2wdrive is offline   Reply With Quote
Old 07-06-2009, 12:50 PM   #6
Chassis preparation is well described here:
http://www.teamcrc.com/crc/modules.p...rder=0&thold=0
brianrice is offline   Reply With Quote
Old 07-06-2009, 04:41 PM   #7
Khador12's Avatar
CAing a chassis is not just for looks. The biggest reason to CA the edges of your chassis is to help prevent delamination of the carbon fibers. When done properly it does look really nice. I use the CRC link above.
Billy Stewart
Xray T4 17
Roche Rapide F1 Evo
Khador12 is offline   Reply With Quote
Old 07-06-2009, 04:45 PM   #8
LOW ET's Avatar
Trader Rating: 97 (100%+)
how many people actually still ca the chassis? i used to do this on all my c/f stuff but have recently just started running parts as is and haven't had a problem.
LOW ET is offline   Reply With Quote
Old 07-06-2009, 04:50 PM   #9
thanx for the info and link
Old 07-06-2009, 06:05 PM   #10
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I never have. I personally think its only advantage is looks. As brittle as CA is, and as hard as the epoxy that holds CF together is, I think its kinda like tying up a yacht with an extra length of yarn, "just in case". I also like to have a sharp edge to measure RH against.
Old 07-06-2009, 06:09 PM   #11
flatspunout's Avatar
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 38 (100%+)
Color the edge of the chassis with a sharpie after sanding, then apply the thin CA with a qtip...the sharpie will turn piano black and shiny. Hotness.
-rocky b
flatspunout is offline   Reply With Quote
Old 07-06-2009, 06:15 PM   #12
great tip, anyone ever tried to do it with a color sharpie? Mabey ad a lil style to it
Old 07-07-2009, 02:17 PM   #13
rtypec's Avatar
Here's what I do...although it's time consuming, the results are precision
Wet sand with 200 grit to knock the edge off the carbon fiber parts.
Liberal amount thin/medium glue applied with qtip/toothpick/whatever.
Wet sand with 200/400/600/1000/2000 (you can skip some if you want)
Polish using a blue paper towel with Mother's chrome/billet aluminum wheel polish.
Mirror Finish!
rtypec is offline   Reply With Quote
Old 07-07-2009, 02:53 PM   #14
you do this to just the edges are the main deck also? with the wet sanding it would cancel out the brush strokes and give it an AWSOME finish
Hi, my name is Daniel and i have a problem, I'm addicted to R/C cars.
***TEAM TERRIBLES***
Old 07-07-2009, 03:05 PM   #15
Super Moderator
What brush strokes?
- RCSpecialties -
Tamiya Enduro 90 Challenge / [email protected] REGISTRATION 03 MAY 2008 LAW Singapore R/C Racers 121 05-24-2008 09:43 PM
Tips for chassis sanding hierog Electric On-Road 30 08-13-2007 09:02 PM
