A Better 4mm Bullet Connector
Finally, someone is making a better 4mm bullet connector:
http://www.amainhobbies.com/product_...-Connector-Set
I don't know how long these have been around - but they are new to me.
The problem with just about every 4mm bullet connector is that all the current flows through little spring loaded fingers with relatively little contact area. They get loose over time and the resistance goes through the roof. It you let it get bad enough - the heat buildup at the connector will melt the female bullet tube right off your expensive lipo pack. I've seen this happen way to many times.
I applaud Castle Creations for designing a better 4mm connector - more in line with the super high current 6.5mm and 8.5mm connectors. They are a little harder to push in and remove, but that's the price for a better connection.
"Fail" belongs to one who did not recognize that and attempted incorrect application of these connectors. They are excellent for the purpose for which they were designed.
The male piece of Castle Bullet connector is designed to mate with the female piece of the Castle bullet connector. Not the plugs in the Orion battery, which is designed for the lower capacity female bullets with the spring ring.
Silly question but I need some electrical eduction here. I'm a bit confused when a lipo is rated at 40c which would means a discharge of 200amps but bullet connectors are rated at 75A-100A and deans at 60A/75A. What am I missing here? I assume the discharge is less than 200amps?
People pay extra for the higher C rating because the packs run stronger, have lower internal resistance and hold voltage better under heavy load compared to lower C rated packs. It's just another advantage that everyone has to have to stay competitive...
These Castle Connectors have been around as long as the Mamba Max ESCs. I agree they are fail if they do not plug directly into the common 4mm female plug on most lipo packs.
I had been looking at these for a LONG time cause they do not have the needlessly swiveling head and wimply springs. I run Orion packs too, and wouldn't mind extra confirmation weather or not they fit...
The Castle Creations 4mm bullet connector is a TIGHT fit on every lipo pack on the market EXCEPT the Orion packs.
All the lipo packs have a 4.00mm diameter female tube, which is what the connector is designed for. The Orion tube measures at 4.20mm which creates a slightly loose fit.
FYI - at about 60-70 amps continuous, it's enough to melt off all the fake Dean's connectors. The fake ones may look the same, but they don't perform the same. The real deans connectors and 12 gauge wire gets pretty darn hot at 150 amps, but do not melt.
60-70 amps is also enough to melt the solder off of a standard 4mm connector. The Castle Creations 4mm connectors should be able to handle a lot more.
