Wire Managment
Old 01-07-2004, 10:31 AM
Intermision's Avatar
Default Wire Managment
Is there a trick to making wiring look neat?
Intermision is offline
Old 01-07-2004, 10:44 AM
One thing you can do on your smaller wire from the esc and servo is to wind them tightly around a small screw driver blade or allen wrench. When you remove the tool they will they retain most of the small spiral shape and look much nicer.
jcrouse is offline
Old 01-07-2004, 11:05 AM
I forgot about foing that. The car looks a lot nicer now.
Old 01-08-2004, 09:01 AM
Trader Rating: 82 (100%+)
try to hide the power & motor wires under the upper deck, if your car has one use zip ties to prevent them from touching moving parts
marvi is offline
Old 01-08-2004, 09:02 AM
dr_hfuhuhurr's Avatar
Trader Rating: 93 (100%+)
Make sure wires are as short as possible without causing binding.
dr_hfuhuhurr is offline
Old 01-08-2004, 09:53 AM
I really can't hide the power wires cause the only go about an inch or two.
Old 01-08-2004, 09:59 AM
Pic 1
Old 01-08-2004, 10:00 AM
Pic 2
Old 01-08-2004, 01:56 PM
Regional Moderator
disaster999's Avatar
that looks like pretty neat already...although i wouldnt curl them cuz i dont like the looks of it
but its clean!
disaster999 is online now
Old 01-08-2004, 02:01 PM
These pics are after I did everything.
Old 01-08-2004, 02:04 PM
I always bunch up my wires and zip tie them.
I wonder if we could figure a way to do all this wiring without the wires? Now that would be clean!
Old 01-08-2004, 07:44 PM
Regional Moderator
haha...WIRELESS!!!
Old 01-08-2004, 09:21 PM
=MisFitz= NuKe's Avatar
lol, hmmm maybe a nano-sized transmitter and receiver for every plug, SWEEEET
=MisFitz= NuKe is offline
Old 01-08-2004, 09:24 PM
I tried making mine wireless, it didn't work to well though.
Old 01-08-2004, 10:03 PM
rough512's Avatar
I tightly bundle the servo and ESC wires then cover them with shrink tubes and heat em. Then I zip-tie the motor and battery wires under the upper deck.
Not having those overhead belts really tidies up the chassis a lot
rough512 is offline
