KO PROPO EX-10 Helios q's >
Old 11-01-2005, 01:31 PM
  #1456
rc-zombies's Avatar
Any word on the Hara Edition Helios coming to the US?
if so..just hope it's not the $700+ pricetag I got from Overseas.
rc-zombies is offline
Old 11-01-2005, 03:49 PM
  #1457
BadSign's Avatar
Trader Rating: 15 (100%+)
Originally Posted by jez
Doesn't that depends on what equipment and what car you are running??
Yeah, I guess it wouldn't hurt to be more specific:
stock 12th scale on carpet, tight track (30' * 50')
stock and mod TC, foam tires, on carpet and coke-syruped asphalt. (high traction, either way)
BadSign is offline
Old 11-02-2005, 12:21 AM
  #1458
beer_drinker's Avatar
Originally Posted by v0rtex
Buzzer? What buzzer?
The sound it makes every time you press a button/dial. It's called a buzzer in the manual.
beer_drinker is offline
Old 11-02-2005, 12:25 AM
  #1459
Oh. Thats the coolest sound it makes!
v0rtex is offline
Old 11-02-2005, 12:31 AM
  #1460
Hmmm... I find it annoying
Old 11-04-2005, 08:04 PM
  #1461
supralative's Avatar
Trader Rating: 16 (100%+)
Read through some pages here and there and couldnt find it. Can you guys help me out.
I will be running the Helios with DSM installed controlling two Airtronics 94358 servos. Would it be beneficial to run the system in high speed, normal, or what? Thanks alot!!!
supralative is offline
Old 11-04-2005, 09:10 PM
  #1462
theisgroup's Avatar
i was able to run it in ahrs mod. this was with a electric with digital servo.
theisgroup is offline
Old 11-06-2005, 11:50 AM
  #1463
V12
V12's Avatar
The Helios should be run in normal mode with the DSM installed and thatīs what Iīm using. Donīt know if the other modes even work with DSM but also never tried.
V12 is offline
Old 11-06-2005, 02:17 PM
  #1464
Spektrum say that the Spektrum will run in all modes on the Helios including AHRS
Old 11-06-2005, 06:27 PM
  #1465
theisgroup's Avatar
based on the ko documentation. running it in standard mode will slow down the processing of information. Basically the response modes control how fast the processer processes info.
like I said it works in ahrs. so it is up to you how fast you want your helios to work.
Old 11-13-2005, 07:20 AM
  #1466
Mission_carbon's Avatar
Hi Guys i need to know a few things. If i got the Helios Radio only what else would i need of coruse i would need a reciver but im not sure what else seeing as i use a normall radio im not sued to these fancy ones yet
Mission_carbon is offline
Old 11-13-2005, 09:46 AM
  #1467
dakrat's Avatar
a transmitter module, Rx, crystals and your set
dakrat is offline
Old 11-13-2005, 07:59 PM
  #1468
Mr KO Staff,
I recently bought a Helios Comp set, it came with black "KR-302F" receiver, but the box cover label stated it came with a "KR-302FS". The shop said it is a "KR-302FS" but with a KR-302F" label as Japan KO never release a "KR-302FS" label receiver before. He did show me some of his Comp set stocks did come with a "KR-302F" receiver. For sure I have seen before a correct "KR-302FS" lebel receiver during my trip in H.K. few months ago.
How do identify the regular "F" model from the "FS" model? I read from some where before the "FS" came with a longer antenna wire. Not sure it is true?
What is the technical difference between the "302FSC" model and the "302FS"? Is it just the carbon look case with the extra cost???
Thanks.
MARKANO is offline
Old 11-13-2005, 08:12 PM
  #1469
beerbarron's Avatar
Can I use my JR recievers with the KO radio? I have two JR and one Novak XXL reciever.
beerbarron is offline
Old 11-13-2005, 08:35 PM
  #1470
dakrat's Avatar
i dont think you can use JR rx with Ko radio. for what radio is the novak xxl? try putting crystals in to see if they work.
dakrat is offline
Copyright Đ 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
