KO PROPO EX-10 Helios q's
#1411
Originally Posted by hype
Hi Guys, One says no, one says yes.
Maybe Mr KO can shed some light on this one?
elnitro: Hype, YES it will work for the Mars/Mars-R
NismoSkyline17: No.
Hi, i've read many pages and not found this answered...someone asked the quesion back in pages 3-5 or so and didn't get answered. Does anyone know if this works? Mr KO Staff?
NismoSkyline17: No.
http://www.spektrumrc.com/DSM/FAQs/Default.aspx
*Will the KO version work with older models of the EX-1 Mars or just the EX-1 Mars R?
All the Mars systems will work.
*Will the KO Helios module also work with the KO EX-1 Mars, KO Esprit, KO Vantage Esprit 2, etc.?
The Spektrum KO module will only fit the Helios and Mars. The two-stick systems use a different module that we may eventually manufacture if there is enough demand.
Don't know where Nismoskyline got his info.
#1412
please read carefully
Hi Guy's...Third try...
Will "KO standard helios module" work in "mars-1" and "mars R"
Also, will the "standard mars-1" and "standard mars-R module" work in the helios?
Also as well...Can anyone please link me to a free download of the helios instruction manual? I'm not paying for something i've alrady bought and misplaced...
thanks for any help...Mr KO Staff, feel free to lend known advice also
#1413
Originally Posted by elnitro
Hehe, I'm using one right now. Here is the link to Spektrum FAQ's regarding KO radios.
#1414
I totally misread the question. My sincerest apologies Nismoskyline. I will now lay off the Capt. Morgan.
#1415
Today I got my new Helios. Just have to wait for the conversion for dropping down the steerwheel. One question on this as I have not found anything in the manual.
When using that steerwheel conversion do you have to calibrate anything afterwards or change anything on the steering settings?
#1416
V12
Go through the VR Adjustment to make sure the steering and throttle pots is correct.
#1417
Do you guys prefer the large grip or the regular one???
#1418
#1419
hype- The Helios module output is way too strong for the Mars series of radios. I would only use the Mars modules in the Mars radios.
V12- Just like Sparx said, do the adjust VR fucntion. I would recommend doing this once a month, just to make sure that everything is in working order.
#1420
Seen this mod on the ko site?
#1421
#1422
It's a mod for adjusting the steering trim on the fly, only available in Japan. The gold wheel is from the Competition version of the Helios.
#1423
#1424
acutts-
The mod is only available from the Japan service department as a limited time option. The gold wheel is only available with the competition version of the Helios at the moment.
-Robert
-Robert
#1425
What size is the gold screws? 3mm, 4mm?
