Old 09-25-2005, 04:23 PM   #1396
does the helios have the mixing option of using the 3rd channel for front brakes on a 5th scale car. thanks
laro is offline   Reply With Quote
Old 09-25-2005, 06:12 PM   #1397
Originally Posted by ntc3freak
open up the radio very very very carefully(did i say very??? ) and blow all the internals with hair dryer.leave it air dry over night before u turn it on again.should be fine
Crab ain't controller suppose to be splash proof? But after drying mine I try it was working fine but I am worried that it will screw up later.
N15M0 is offline   Reply With Quote
Old 09-25-2005, 07:32 PM   #1398
forty6's Avatar
I don't believe it has mixing. I know that the 3PK has that.
forty6 is offline   Reply With Quote
Old 09-25-2005, 09:44 PM   #1399
ntc3freak's Avatar
if it doesn't work it's toast .don't worry,just send it for repair
ntc3freak is offline   Reply With Quote
Old 09-26-2005, 08:25 AM   #1400
forty6 thanks for the reply.
Old 09-26-2005, 11:48 AM   #1401
CypressMidWest's Avatar
Quick Question that's probably already been asked a million times, Will the Helios work with the 301f receiver? I understand it would be at a slower rate than with the 302f but I was just wondering if there were any other that would prevent it from working.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 09-26-2005, 11:52 AM   #1402
Hebiki's Avatar
Trader Rating: 26 (100%+)
yes it will work.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 09-26-2005, 12:07 PM   #1403
Originally Posted by Hebiki
yes it will work.
THANX!
Do you run it in AHSR or normal mode when using a 301f Hebiki?
Old 09-27-2005, 04:30 AM   #1404
BrainTeased's Avatar
THANX!
with the 301 recievers you need to set your transmitter to run 3 channels as this puts the helios in super HSR (like the mars R)
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 10-07-2005, 08:08 AM   #1405
Suspended
Trader Rating: 8 (85%+)
Send a message via Yahoo to hype
Default Will the helios module work in mars 1 and mars R?
Hi, i've read many pages and not found this answered...someone asked the quesion back in pages 3-5 or so and didn't get answered. Does anyone know if this works? Mr KO Staff?
hype is offline   Reply With Quote
Old 10-07-2005, 08:51 AM   #1406
Laterilus
PM sent. I PM'd you my experience using the spektrum on an ex10. Hopefully it helps.
Originally Posted by Laterilus
KO PROPO staff,
Thanks for the follow-up. I almost never remove my module for that very reason. When I removed my spektrum module to send it in, I carefully inspected every pin and noticed no wiggling or looseness what so ever. When I do have my spektrum equipment returned and if the problem continually happens, I can only assume at that point it is the transmitter. With any luck, I can get a hold of my friend that lives near by and borrow his module and receiver so I can test if the transmitter continues to display the same problem as what it does with the spektrum installed. If it turns out that the transmitter is the problem regardless if I use a spektrum module or the KO crystal module, does it matter if I send my Helios in for service with no module attached? I don't own one, I only bought the transmitter that came with the Mini Z module.
snowboardgeek1 is offline   Reply With Quote
Old 10-07-2005, 10:53 AM   #1407
R/C Tech Charter Subscriber
No.
NismoSkyline17 is offline   Reply With Quote
Old 10-07-2005, 01:36 PM   #1408
Hype, YES it will work for the Mars/Mars-R
elnitro is offline   Reply With Quote
Old 10-07-2005, 06:28 PM   #1409
Suspended
Hi Guys, One says no, one says yes.
Maybe Mr KO can shed some light on this one?
elnitro: Hype, YES it will work for the Mars/Mars-R
NismoSkyline17: No.
Old 10-07-2005, 10:44 PM   #1410
hey just wonder if there will be a "hara conversion kit" released by KO? i just love that bling bling purple wheel
yellow15 is offline   Reply With Quote
ko propo helios alexisonfire Australia For Sale/Trade 7 03-06-2008 04:19 AM
KO PROPO EX-10 Helios 40 Mhz jca2000au Australia For Sale/Trade 0 12-06-2007 09:03 PM
**EX-10 HELIOS KO PROPO*** nsupra R/C Items: For Sale/Trade 8 08-14-2006 09:11 PM
Ko Propo Ex-10 Helios hurley081182 R/C Items: Wanted to Buy 1 04-03-2005 07:58 PM
F.S.> KO Propo Helios... plus Bwadd2002 R/C Items: For Sale/Trade 7 05-19-2004 09:40 PM
