KO PROPO EX-10 Helios q's >
Old 07-15-2005, 10:07 AM
  #1231
theisgroup's Avatar
i was doing that until i pushed one of my pins loose. this cause me all sorts of grief one weekend. So I fear pulling the module with any frequency. those pins on the back are soo fragile. they were never ment to be see with any frequency.
theisgroup is offline
Old 07-18-2005, 07:20 AM
  #1232
tc3 racer sc's Avatar
Default where i need to send my helio for service
i need a address to send my helio the prongs in the bck of the radio that hold my spectrum transmitter is lose or would u say the pins to keep it in place it very lose and u can shke it thxs need info
tc3 racer sc is offline
Old 07-18-2005, 11:30 AM
  #1233
Repair center addresses
KO PROPO Staff is offline
Old 07-18-2005, 06:45 PM
  #1234
Originally Posted by KO PROPO Staff
thxs
Old 07-18-2005, 06:54 PM
  #1235
Originally Posted by Mr. Shookie
DO not store or travel with the modual in it....I am still trying to find a case that can hold both....
Hi Shookie, Check out the Speedmind Helios soft case/bag. One of the guys I race with has this case and the radio fits perfectly with the spektrum module still loaded in the back, the case has foam cut out under where the module sits to protect the spektrum antenna.
v0rtex is offline
Old 07-18-2005, 07:55 PM
  #1236
Still Bill's Avatar
Trader Rating: 16 (100%+)
My Speedmind case is working great with my Helios and Spektrum. Padding is cut to accommodate Spektrum antenna.
Only problem is that I really miss my signed red Matt Francis tranmitter case.
Still Bill is offline
Old 07-19-2005, 07:56 AM
  #1237
Mr. Shookie's Avatar
You the MAN...LOL
I will have to pick one up as soon as I see one....
Thanks,
-Shookei <><
Mr. Shookie is offline
Old 07-22-2005, 07:44 AM
  #1238
BrainTeased's Avatar
hi guys
got a question about the reponse modes
at the back when you take out the module you'll see a switch
- high speed
- normal
i was wondering if anyone remembers what their radios came factory set at? if they have already taken out the module and flicked the switches
i dont wanna take my module out as i've heard that by doing so you could loosen the pins in the module or something.
appreciate any help
thanks guys
BrainTeased is offline
Old 07-22-2005, 09:28 AM
  #1239
Thraex's Avatar
Taking out the module for one time can't hurt!
It's a bit fragile, but not that fragile, trust me...
Thraex is offline
Old 07-22-2005, 11:18 AM
  #1240
Originally Posted by BrainTeased
hi guys
- high speed
- normal
appreciate any help
thanks guys
The radio comes with the switch in the High (H) position and 2 CH mode (Advanced HSR) from factory. Pulling the module out does not hurt the pins. SLAMMING the module into the radio does. You can brake the solder joints and/or the PCB trace. Just take care when re-installing the module.
-Robert
Old 07-22-2005, 11:27 AM
  #1241
dado11g's Avatar
hi, i just have a few quick questions. 1st, is there any other brands of crystals that i can use in my helios?
will the new jr synthesised module work in the helios?
what are the clearest fm 75mhz channels?
thanks alot
marshal v.
dado11g is offline
Old 07-22-2005, 07:06 PM
  #1242
i just got my bag in from allspeedhobbies very nice well since my pins are lose im going to send the helio in and use my bck up radio mars to run this weekend
Old 07-22-2005, 08:24 PM
  #1243
Hebiki's Avatar
Trader Rating: 26 (100%+)
thanks alot
marshal v.
using the ko propo crystals is your best bet. they are calibrated exactly at the factory giving you the cleanest signal. you can try the spektrum module if you want something synthesized. the spektrum has gotten the best feedback yet from helios users.
Hebiki is offline
Old 07-22-2005, 08:52 PM
  #1244
Still Bill's Avatar
Spektrum...Spektrum...Spektrum.................... And never look back!
Old 07-22-2005, 09:21 PM
  #1245
dado11g's Avatar
well, i wish i could afford it, how much does the whole system cost? and i will need an extra reciever or two
dado11g is offline
