KO PROPO EX-10 Helios q's >
Old 06-14-2005, 10:57 AM
  #1141
Originally Posted by jez
Hi all,
I have just severed the antenna wire off my kr302f. The car flipped and grinded the antenna tube right through. Question is, can i replace this with wire of the same gauge and length, or can i just rejoin the two halves, or any other suggestion?
What might the wire gauge be if I can replace it?
Oh an another is I live in OZ, so I can really send it to Ko Staff here...
Thanks guys
Replace the wire with a new one. 26GA, 13 1/2 inch to 15 1/2 inch. The longer 15 1/2 inch would give a little more range if needed.
-Robert
KO PROPO Staff is offline
Old 06-14-2005, 05:58 PM
  #1142
jez
jez's Avatar
Thanks Robert for the quick reply.
jez is offline
Old 06-14-2005, 09:55 PM
  #1143
jez
jez's Avatar
sorry Robert, one more question...
is the antenna wire different for the different mhz receivers? You have a 27mhz -black- and a 75mhz -gray- wire on the KO website. My receiver is a 40mhz with white wire.
Can I use antenna wire from an old KO receiver? (It is an AM RX from the old EX-5 transmitter - can't remember the name).
And to confim - wires to be 26gauge.
Thanks again.
jez is offline
Old 06-19-2005, 07:31 AM
  #1144
BrainTeased's Avatar
hi guys i was wondering if you can use the Mars R receiver (301) with the Helios transmitter?
and is Helios avaliable in 2 modes? PPM and advanced HSR? or just the advanced HRS?
thanks in advance guys
BrainTeased is offline
Old 06-19-2005, 08:25 AM
  #1145
Thraex's Avatar
The Helios has 3 different modes.
The normal mode, you can use it with every FM reciever (with the same freq.).
HSR, that's the mode you can you use with the 301 reciever.
And finally it has the AHSR (advanced) mode, that's the fastest and can be used with the 302 reciever.
Thraex is offline
Old 06-19-2005, 09:15 AM
  #1146
Still Bill's Avatar
Trader Rating: 16 (100%+)
And I use advanced mode with the Spektrum radio/receiver?
Still Bill is offline
Old 06-19-2005, 09:25 AM
  #1147
Thraex's Avatar
You can change the modes on the transmitter.
If you take the module out you can flip a switch, you can put it in normal- or HSR mode.
If you picked the HSR mode, you can change that mode in the menu, advanced or HSR (3 of 2 way).
I thought if you're using the spectrum, you can put it in advanced.
The spectrum is just as fast as the helios in advanced with the 302 reciever, but correct me of I'm wrong.
Thraex is offline
Old 06-20-2005, 03:16 AM
  #1148
thank you very much for clearing that up for me tekin! cheers!
Old 06-20-2005, 03:24 AM
  #1149
Davo's Avatar
Hey,
how do I get the advabced working in my Helios or is already activated??
Davo
Davo is offline
Old 06-20-2005, 03:43 AM
  #1150
Tommy Bergfeldt's Avatar
Advanced HSR is only available in 2ch-mode, so to have the mode to AHSR you choose 2 channel in the menus, i'mnot certain what name the menu has but you should be able to find it
Tommy Bergfeldt is offline
Old 06-20-2005, 03:55 AM
  #1151
Thraex's Avatar
@ BrainTeased,
You're welcome!
@ Davo,
Put your transmitter on, scroll with the scroll wheel to "CH.Select" (channel select) and select 2way.
You can also check it out on page 57 of the manual.
Thraex is offline
Old 06-20-2005, 03:49 PM
  #1152
Do you guys have a helios manual in PDF or Word???
Thanks in advance for your help.
Hugo is offline
Old 06-22-2005, 09:26 AM
  #1153
Default KR-302FSC
Saw at Ko web new helios TX and RX KR-302FSC will be out soon.What is the extra about it?
faiunie is offline
Old 06-22-2005, 09:41 AM
  #1154
Module and reciever that will give even higher speeds than AHSR, kind of Super AHSR
Old 06-22-2005, 12:27 PM
  #1155
axel's Avatar
I wonder how much the competetion helios will be? All i really want from is the gold wheel, gold screws, and the stickers.
axel is offline
