Old 05-01-2005, 07:42 PM   #1051
theisgroup's Avatar
Originally posted by HarshGuy
S0 I'm assuming you had esc's and servos to take advantage of the AHRS? ...did you notice any response difference at all with the spektrum vs. the 302f?
no not really as far as response. but i normally run in ahrs. never really run it in standard mode. I am running 1/12 so have a 949ics and running a keyence esc.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 05-01-2005, 07:43 PM   #1052
theisgroup's Avatar
Originally posted by axel
Hey so i tried this charger, i tried plugged it for about 1 second to make sure nothing bad happens, and when i did my helios would trun off then when i took it out it turned back on.
that is normal
yang lai
Old 05-01-2005, 08:11 PM   #1053
axel's Avatar
but i don't know if the chrager specs that i listed in the page before are compatible for my 2000mah radioschack batteries.
axel is offline   Reply With Quote
Old 05-01-2005, 08:22 PM   #1054
theisgroup's Avatar
i am not sure that the one you posted will work. if you look at an 8 cell AA. that is like 9.6 volt. so you should be supplying at least that to the cells to put a charge on it. as far as maps go, you can go as much as .5amp. but I woul d not go too much more. I think the one I have is a 12volt output.
yang lai
Old 05-01-2005, 08:37 PM   #1055
axel's Avatar
which one do you use and will it be able to charge 2000mah?
Old 05-01-2005, 09:04 PM   #1056
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Just got the helios with a 2500 mah battery pack that comes with the standard receiver plugs. Does anyone know the correct polarity of the 3 pins in the controller.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 05-01-2005, 10:44 PM   #1057
theisgroup's Avatar
i use an old futaba one. has a port for the radio and a reciever pack
yang lai
Old 05-01-2005, 10:47 PM   #1058
theisgroup's Avatar
Originally posted by danjoy25
Just got the helios with a 2500 mah battery pack that comes with the standard receiver plugs. Does anyone know the correct polarity of the 3 pins in the controller. Would this short the transmitter if I connect it incorrectly?
you should look back a page or 2, i posted the pin out for that. + is toward the back of the radio and - is in the middle. nothing toward the front
yang lai
Old 05-02-2005, 03:03 AM   #1059
First race yesterday with my Helios/spektrum : great great great !
No glith at all, whereas a lots of drivers with "classic" radios had at 2 parts of the tracks!
I have another question: i can't find how to set the steering balance: it's 70%/70% and the enter button doesn't allow me to edit these values. I would like to be modify my EPAs...
BTW i know that if the front is purely setup i should not have to set a different EPA for left & right. Yesterday the difference was very subtle but it exists.
charlymbx5 is offline   Reply With Quote
Old 05-02-2005, 03:44 AM   #1060
Regional Moderator
daniz24's Avatar
Just go to ST BALANCE menu, and after that turn the steering wheel to right direction until the mark * shows and then you can adjust your right EPA. Same with left EPA. If the mark * not appear, you must go to ADJUST VR menu to re-calibrate your Helios.
daniz24 is offline   Reply With Quote
Old 05-02-2005, 04:16 AM   #1061
Thanks, i'll try asap!
Old 05-03-2005, 09:55 PM   #1062
danjoy25's Avatar
Has anyone tried the KO Tamiya wheel adapters for the radio? Please postpics if you have any and whats the best rims to use.
Old 05-03-2005, 11:10 PM   #1063
Mr. Shookie's Avatar
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
I tried the Integy one and it broke right after I got it....
The stock one is great just had to get the old school sprocket looking grip from Kimbrough.
Me loves it.....(in my best GOMER voice)
Stephen<><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 05-04-2005, 05:01 PM   #1064
=MisFitz= NuKe's Avatar
Send a message via AIM to =MisFitz= NuKe Send a message via Yahoo to =MisFitz= NuKe
Yep...works great...use whatever rim you want to...make sure it looks cool though.
=MisFitz= NuKe is offline   Reply With Quote
Old 05-04-2005, 05:46 PM   #1065
danjoy25's Avatar
That looks made, can wait to get my adapter and extension. You wouldn't happen to be selling a spinning wheel for me to use.
ko propo helios alexisonfire Australia For Sale/Trade 7 03-06-2008 04:19 AM
KO PROPO EX-10 Helios 40 Mhz jca2000au Australia For Sale/Trade 0 12-06-2007 09:03 PM
**EX-10 HELIOS KO PROPO*** nsupra R/C Items: For Sale/Trade 8 08-14-2006 09:11 PM
Ko Propo Ex-10 Helios hurley081182 R/C Items: Wanted to Buy 1 04-03-2005 07:58 PM
F.S.> KO Propo Helios... plus Bwadd2002 R/C Items: For Sale/Trade 7 05-19-2004 09:40 PM
