Old 03-20-2004, 04:41 PM   #91
Just got my Helios Thursday. Love it! Raced today with it. HSR mode is actually a difference I could feel.
The balance and feel of the transmitter are great. The menu system is very easy to use and manipulate, which is a very good thing since the manual is painful to understand. The flow charts that go all over the page in different directions give me a headache. I've pretty much got everything figured out by trial and very little error.
octavio: Did you go through the set up menu to assign functions to the the buttons? This must be done first before any of the timer stuff functions. I believe I have my lap timer assigned to bt2 or 3. I don't have my transmitter near me at the the moment.
When you're ready to use the lap timer, you go to lap timer in the menu, where you should see:
Lap Timer
0:00:00
When you see that, you then press and hold the + and - buttons at the same time.
It should then be flashing.... READY
When you next pull the trigger, the timer starts. You then press the the button you assigned for each lap.
Hope that helps
Bodido is offline   Reply With Quote
Old 03-21-2004, 06:06 PM   #92
Motorman007's Avatar
Trader Rating: 81 (100%+)
Bodido,
(Just got my Helios Thursday. Love it! Raced today with it. HSR mode is actually a difference I could feel.)
are you using Dig servos?
Motorman007 is offline   Reply With Quote
Old 03-22-2004, 09:12 AM   #93
Hello all.
Is there some here that tells you what all the extra setting on the radio do and how it would work if you did this and did that.
Ex.
Like the Expo, Trim rate
Response
Digital trim
Dual rate extra.
Th-speed
I need this info so I can see how it works on my 1.8.
This weekend I drove a buggy same every thing but the expo was -60 and it was so easy to drive.
Then I set my expo to -60 on my radio and wow same thing. Very easy to drive.
I had it on 0 all this time for the last year now.
But man it was so much easier to drive. Track was super slick but when I put it on -60 it had very little wheel spin and I was able to put the power much more smoother.
Well if you some can point me to the right place so I can see what else Iím missing to help me out.
Thanx Dibs
Old 03-22-2004, 12:41 PM   #94
Actually, I'm not using a digital.
I'm using a Futaba 9402 in my B4, which is a fairly fast high-end analog, and it works just fine. ESC is a gt7.
It's in full HSR mode, even with ch select set to 2.
I switched it in and out and could clearly make out the difference. Definately felt more connected and responsive. Particularly noticeable when making countersteer type steering corrections.
Old 03-23-2004, 08:52 AM   #95
so if i was to use digital servo it would be even better you think? or is that over kill. i was going to use the digital servo in my kyosho Kanai 3. and in my Kyosho Truck.
i was going to get two sets
PDS-2343 FET ICS PDS-2344 FET ICS
right now i have the Air 359's in the truck and 359 in the 1.8.
but i was told that digital servo was a no no for 1.8.
but also KO PROPO Staff said that the new PDS servos are bomb proof.
KO PROPO Staff could you inlighting me on this.
thank you
dibs
once i close on my home on next tues.
my ele. gear is going to set me back about 880 bucks
but i like to have the best.
Old 04-08-2004, 03:30 PM   #96
yo my baby came in today. i must say it is really nice. now to read the book. lol
ko radio
ko 2
ko 3
can not wait to try it out this weekend.
Old 04-09-2004, 07:48 AM   #97
ok do i miss with the ST:TRAVEL or leave it at 100?
and my End Point Adjustment is the Balance?
and which is my expo. the curve?
and what order do i do things?
ST:TRAVEL first
then
ST:BLANC or Balance
then i Remove the servo arms from the servo?
Old 04-09-2004, 08:00 AM   #98
1) Set travel to 100
Travel = dual rate
2) Set balance to very low number before reciever is on
3) Turn on reciever
4) Increase the values in balance to just before the linkage is bound, but not past!
5) Travel is then used to reduce steering throw while you're already on the track. Travel can be adjusted by the upper of the two thumb rocker switches as well as through the menu.
Old 04-09-2004, 08:15 AM   #99
got it!!
and what about the expo? which one is it for gas and the steering
also should i use the punch and the TH accel?
thanx man
Old 04-09-2004, 10:23 AM   #100
octavio's Avatar
expo = st. curve
mine is at 1- 10% , depends on the track
punch / th accell ,just try it and find out
good luck
it's a hell of a nice radio.
octavio is offline   Reply With Quote
Old 04-09-2004, 10:27 AM   #101
thank you. that's what i was thinking.
again thank you for your time.
dibs
Old 04-09-2004, 10:44 AM   #102
one more thing what is the part# for the charger to hook to the back of the Helios? like the M8 and Futaba radio's
thanx you
Old 04-16-2004, 04:31 PM   #103
rc_square24's Avatar
Default 27 or 75mhz?
Im thinking of gettin the helios but whats the difference between the 27 and 75 mhz module?
thanks
rc_square24 is offline   Reply With Quote
Old 04-16-2004, 04:40 PM   #104
Default Re: 27 or 75mhz?
thanks
In the US, there are 6 channel in 27Mhz(1-6) band and 30 channels in 75Mhz (61-90). Outside the US, there are 12 channels in the 27Mhz band. KO sell crystals for all 12 channels in the U.S. for some reason.
Also, 75Mhz is close the frequency of flouresent light bulbs so you might experience glitching in some situations.
Headbanger is offline   Reply With Quote
Old 04-16-2004, 05:59 PM   #105
so if ill be using it in canada, which should i get? 27, 40 or 75?
i managed to get 40 mhz in hk.
ko propo helios alexisonfire Australia For Sale/Trade 7 03-06-2008 04:19 AM
KO PROPO EX-10 Helios 40 Mhz jca2000au Australia For Sale/Trade 0 12-06-2007 09:03 PM
**EX-10 HELIOS KO PROPO*** nsupra R/C Items: For Sale/Trade 8 08-14-2006 09:11 PM
Ko Propo Ex-10 Helios hurley081182 R/C Items: Wanted to Buy 1 04-03-2005 07:58 PM
F.S.> KO Propo Helios... plus Bwadd2002 R/C Items: For Sale/Trade 7 05-19-2004 09:40 PM
