KO PROPO EX-10 Helios q's >
Old 03-26-2005, 09:43 PM
  #961
Mr. Shookie's Avatar
You have to reset the VR, go through the menu and got to the VR settigns and reset everything to zero. I recommend you read the section in the instructions because it will give you the step by step.
After you have done this everything will be set up just right.
Hope this helps,
Stephen <><
Mr. Shookie is offline
Old 03-26-2005, 10:44 PM
  #962
dakrat's Avatar
ive heard people have glitching problems with their helios and amb personal transponder. is this still a concern? some say to keep the amb as far from the rx as possible but its for a 12th scale and the space is very limited. im getting an amb soon and just wondering if this is still a problem?
dakrat is offline
Old 03-27-2005, 06:01 PM
  #963
dakrat's Avatar
one more dumb question, how do u change the tx crystal? do u have to dig it out of the module?
dakrat is offline
Old 03-27-2005, 06:05 PM
  #964
Pro4's Avatar
get a descent hold of it and just pull it out
Pro4 is offline
Old 03-27-2005, 06:21 PM
  #965
dakrat's Avatar
can someone anwer this before i install PT
dakrat is offline
Old 03-27-2005, 06:28 PM
  #966
wannabee's Avatar
It's not a big deal, the Helios is one of the least radio's to give you problems! Mount the PT on the chassis or on the servo.
Been runing mine for a while now no problems at all!
KE
wannabee is offline
Old 03-27-2005, 07:47 PM
  #967
dakrat's Avatar
a few people in this thread had problems with helios and PTs when installed close together. im give it a shot.
dakrat is offline
Old 03-27-2005, 07:53 PM
  #968
=MisFitz= NuKe's Avatar
I mount my PT right on the servo, and never have had a problem.
=MisFitz= NuKe is offline
Old 03-28-2005, 03:04 AM
  #969
Tommy Bergfeldt's Avatar
I had massive problems with glitching when i had my PT on the servo when i was using 40 mhz. Since i switched to 27mhz i've had no prolems at all...
Tommy Bergfeldt is offline
Old 03-28-2005, 06:16 AM
  #970
theisgroup's Avatar
i run my pt on my servo on 40 with no problems.
side note on spektrum. I watch a spektrum yesterday that was running ok, then after a tap of the boards, had to be reset by turning it off and then back on. Also i hear from a couple of the users that you do infact had to trun off the hrs mode.
theisgroup is offline
Old 03-28-2005, 10:55 AM
  #971
dakrat's Avatar
i think the PT on the servo has nothing to do with glitching, its the space between the rx and the PT. anyone here running 12th scale where space is an issue?
dakrat is offline
Old 03-28-2005, 11:00 AM
  #972
theisgroup's Avatar
i am running it in a bmi 1/12 and assoc 12l4. but I have the pt at the front fo the car just under the front center brace.
Old 03-28-2005, 11:33 AM
  #973
Default Re: Wall Charger
Originally posted by Tire Chunker
Can I use my JR wall charger with the Helios?
Polarity is different on the plug. Do not use it.
KO PROPO Staff is offline
Old 03-29-2005, 08:15 AM
  #974
Tire Chunker's Avatar
Trader Rating: 16 (100%+)
cut and change the wires to change - + on plug?
Tire Chunker is offline
Old 04-05-2005, 12:24 AM
  #975
ghoppa's Avatar
Trader Rating: 63 (98%+)
I really could'nt find the "thread" to ask this question, but I figured I had a good chance on this one......
question: does the LRP Phasar (27MHz) receivers work with the "ol' skool" EX-1 Mars-R????
I was wondering 'cause I have been running a M8 for a 2 years know, and I'm really starting to miss the "feeling" I had with the Mars Radio
ghoppa is offline
