KO PROPO EX-10 Helios q's
#811
i'm using the receiver that came with the EX-10
302F is it?
I haven't change any settings on my tx/esc since last time i went to the track. The only thing i changed is replaced the trinity monster stock motor with a silver can and the spur/pinion gear.
oh one thing i changed is the throttle high point from 150 back to 100 but i don't think it'll make the car stop responding?
302F is it?
#812
i'm running at advanced response mode i think?
the switch at the back of the module is up and i set the tx to "2 channel" only.
#813
think of it again, it looks like the car has a "power save" mode or something that shut itself down after idleing for X amount of time?? (it's not happening all the time thou)
is this a hidden function from KO?
another thing, i got a friend with a 27MHz Mars
would it be okie if we swap the tx modules so that i can test my tx/rx separately?
#814
ok, i took it to my local hobby shop and went to the track again early. and found there are two problems:
1 the connector to the battery does not have a very good connection sometime so i have it replaced.
2.when i use the lap timer function.. after i finish the run, i press the "enter" key to stop it, and then "+" and "-" to reset the timer, and the car would stop responding immediately. Another guy at the track is using a Mars R (he's the national champ) so i asked him to help me have a look and he can't figure out why is it as well. The funny thing is it doesn't happen every single time. If we restart the tx and try the lap timer and follow exactly the same procedure again, then it may be ok this time (but most of the time it doesn't work), we then spent 15 mins trying a lot of things but it seems as soon as we reset the timer, then (most of the time) the car would just stop moving until we restart the tx. Another thing he noticed is that when we start the lap timer, the "LAP. T " display does not always start from 0. It starts from 0 sometimes but it doesn't some other time... but it has no real relation with either the car will stop responding after we restart the timer.
So does anyone here got this problem as well? or KO staff,... any idea why is it and how can i solve the problem?
#815
Never heard or seen that before. You should problably send it in so a tech can take a look at it.
#816
so it's a faulty tx
it looks like a software bug to me as the tx is working perfectly fine if i don't use the timer function.
Any way i can reset/anything else i can do as i bought the EX-10 from oversea and is a pain for me to send it back for check.
#817
Originally posted by yellow15
so it's a faulty tx
so it's a faulty tx
Have you tried using a receiver battery connected to the recevier and use only servos? Not using the esc. Does the problem still happen? If it doesn't then, it's the esc.
#818
yes they are an authoirsed dealer,
I just talked to our local shop that sells KO product (who helped me to test my ex-10 as well) and they told me on average it would take 3-4 months before i can get it back if i want to send it to Japan for repair. i don't really want to be without my ex-10 for so long as i only have a spare cheap sanwa AM radio.
Thanks for your suggestion about trying receiver battery. But i doubt ESC is the problem as the "T lap" count on my ex-10 display is also not correct when i'm using the lap timer.
But i'll replace the ESC with a VFS-1 tonight and see if it makes any difference
and let you know
#819
what servos can i use if i want to use Advanced HSR??must it be ko's servos??
#820
#821
#822
and let you know
I've tried the up timer and down timer and both of them are working fine..
just the lap timer which is the only timer i want to use damn it
#823
hey guys,can i charge my ni-mh AA cells through the transmitter(helios of course)???it is wall charger and charges overnight.can i charge using it through the transmitter?thanks
#825
Originally posted by Jamie Corrado
NTC3FREAK,
You shouldn't have any problems using the wall charger. Just monitor the heat coming from the batteries and do not overcharge. I would check the voltage like every hour or so.
NTC3FREAK,
every hour???i cannot sleep???
