Old 01-27-2005, 08:54 PM   #766
Tim Johnson's Avatar
travis you really need to change your avatar....lol
_______________________________________________________
Support your Local Hobby Shop, because you can't race on Ebay!
Airtronics|Kyosho|
Tim Johnson is offline   Reply With Quote
Old 01-27-2005, 08:59 PM   #767
Travis S's Avatar
Trader Rating: 46 (100%+)
I may after that JRXS comes out. I like how that car is setup.
Travis S is offline   Reply With Quote
Old 01-27-2005, 09:06 PM   #768
Travis S's Avatar
Originally posted by ntc3freak
yeah.that is the one i downloaded.how to use it??can u explain it to me?i am a newbie,so i dont understand everything.thanks
Open the program and click on NEW
Then double click on one of the custom tones
Then select OPEN and find one of the files that you downloaded from my other link.
this will bring it up and give you the info you need to type in to get the song...
That is what my picture shows above. Me opening a song from a file I downloaded.
Old 01-28-2005, 04:19 AM   #769
ntc3freak's Avatar
it really isn't hard(not as i tought).it is very easy.thanks travis for ur help.
ntc3freak is offline   Reply With Quote
Old 01-28-2005, 04:55 AM   #770
ntc3freak's Avatar
guys,can u use ni-mh cells in the helios?i will not cahrge the batteries via the charging jack,but will take it out and charge it externally(using a tx charger).but the question is,can i use it in the helios?thanks
Old 01-28-2005, 06:26 AM   #771
Cole Trickle's Avatar
Default Re: Calling Cole Trickle
Originally posted by KO PROPO Staff
The speed reference according to your model would be the YY. This is what is increased. I doubt that you can feel the difference when going from neutral to the servo end point 0.06s /60 deg. You will feel and see the difference on the response in moving the servo back and forth rapidly.
The difference in frame rate, is it to a certain degree similar to the difference between a analog and a digital servo?
An analog servo motor recieves 50 pulses pr. second, where a digital servo get 300...
There are more differences between a analog and digital servo, and the comparision also requires, that specs like speed and torque are even. So such a comparision aint excatly waterproof
But the difference in amount of pulses sounds similar to difference in frame rate...
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 01-28-2005, 06:29 AM   #772
Futaba have made this explanation of digital servos: http://www.futabarc.com/servos/digitalservos.pdf
If you guys at KO could come with an explanation of frame rate at the same level as this, you guys would be the best Because I dont think anyone have done that before
Old 01-28-2005, 11:58 AM   #773
Hebiki's Avatar
Trader Rating: 26 (100%+)
i use energizer nimh designed for digital cameras. you can also use the GP2300s.. or any other rechargable batteries out there.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 01-28-2005, 12:01 PM   #774
Hebiki's Avatar
Default Re: Re: Re: Re: Helios versus Presto
Originally posted by Mr. Shookie
You quickly find that it does everything but toast bread...LOL
wow! you got the old helios. i have the Helios French Maid Edition 2005. it makes scrambled eggs, toast and bacon. freshly squeezed OJ too!
Hebiki Design Works
Old 01-28-2005, 08:11 PM   #775
Man I did not know about the French bread edtion.....
o well, I picked up the New 2005 pit man edition
for an extra 129.99 you can get this option added.
Full version
Airtronics|Kyosho|
Old 01-29-2005, 05:54 PM   #776
ntc3freak's Avatar
Full version
Old 02-01-2005, 09:03 AM   #777
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Well, i found a solution to my interferences on my Helios, came up to that one of the pins that the module connect to the transmitter was loose on the circuit board. Just took the radio apart and soldered the pin again and the radio works great again
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 02-03-2005, 04:48 AM   #778
ntc3freak's Avatar
guys,i am getting a helios next weekend.i just want to know are there anything that i should look out for?
Old 02-03-2005, 05:06 AM   #779
Hebiki's Avatar
also check your crystal pins. i bent one and my car was whacky!
Hebiki Design Works
Old 02-03-2005, 05:07 AM   #780
Hebiki's Avatar
make sure you turn up your steering travel all the way up... then adjust accordingly if its binding the servo.
Hebiki Design Works
ko propo helios alexisonfire Australia For Sale/Trade 7 03-06-2008 04:19 AM
KO PROPO EX-10 Helios 40 Mhz jca2000au Australia For Sale/Trade 0 12-06-2007 09:03 PM
**EX-10 HELIOS KO PROPO*** nsupra R/C Items: For Sale/Trade 8 08-14-2006 09:11 PM
Ko Propo Ex-10 Helios hurley081182 R/C Items: Wanted to Buy 1 04-03-2005 07:58 PM
F.S.> KO Propo Helios... plus Bwadd2002 R/C Items: For Sale/Trade 7 05-19-2004 09:40 PM
