KO PROPO EX-10 Helios q's
#676
I bought a KO Helios recently, and it's awesome.
But i've encountered a problem: My analog Hitec servo(625MG) went totally nuts when i installed it, so i borrowed a PDS-2143 servo at the first race with the radio. It worked flawless, and my car was never so easy to drive. When i got the cash to buy my own servo, a PDS-2363 it didn't go all that well. The servo makes weird noises all the time, something the PDS-2143 did not. The servo seem to operate fine, but the noise is freaking me out. Haven't tried the car on the track yet, just in my pit at home.
Is this normal or is the servo ruined?
#677
wait kind of noise is it making? does it sound like the servo is constantly on, like a buzz? if so thats normal (most digital servos are constantly trying to center), but i would suggest you make sure you are not in super HRS mode if you still run an analog servo.
Ko propo rocks, but word to ko propo staff, ADD STICKERS TO THE RADIO!!!!! you pay $$$ for it and you dont even get stickers, come on. LOL.
#678
The sound is not like normal servo operating sound, and its only there from time to time. I guess it'll work out just fine.
Yes, some decals would be nice! None of the KO products include decals, that really sucks. When Peak includes decals with $3,50 brushes, you should include them with $250+ radio gear.
The user manual is also kind of cryptic, not super easy to navigate through and understand. Futaba manuals are a lot better......
#679
one thing to check tho, make sure your crystal pins (the crystal that goes into the receiver) isnt bent. same with the one for the radio. it'll cause the radio to not have a solid connection with the crystal and might cause your car to glitch.
#681
What could be causing my car to glitch at a certain point on the track only when running with 6+ people on the stand. Doesn't happen at all when it is just me practicing and also happens between cars. Happens on channel 69-70 on two diff radios and 3 diff receivers. Swapped in a 27 mhz module and receiver and had no problems. I've component swapped everything but the 75 mhz module and I will try some other channels this weekend. This is indoor with flourescent lighting. What is the formula for cross-frequency modulation? The other channels were:77, 63,82,70 (me), 62. Any ideas? I am getting extremely frustrated.
#682
I've noticed a lot more people having glitches on 75mhz than any other frequency. I use 40mhz and 27mhz and never glitched in our track, which is surrounded by wire fence and has alot of flourescent lights in the pits, which is in front of the track.
#683
ive never had a problem with glitching on the 75 band. But im also on crystals 89 and 90. Others at my track run 69-70 and never had that problem, and we have big out door lighting and wire fence around our facility. Has anyone else had that problem within those channels at your track, if so, then its not just you. Also what i would do is make sure none of your crystals are bad or anyone elses crystals that are close to your frequency are bad. one time at the track, somone had a bad set, and it would cross over different channels, so a few people had recieved interference.
#684
#685
anybody using the helios with a futaba 9650 servo?Do all response modes work?
#686
#688
Good. I need a new 12th scale servo and like the Futaba http://www.servocity.com/html/s9650_mini_digital.html
I had an M8. Had a cheap feel to it and drank batteries. Helios has a better feel I think.
