KO PROPO EX-10 Helios q's >
Old 08-09-2004, 08:20 PM
  #226
forty6's Avatar
Originally posted by KO PROPO Staff
Just slightly cheaper, about $50.
Is this a hard or a soft case?
forty6 is offline
Old 08-09-2004, 09:23 PM
  #227
TFR
TFR's Avatar
soft bag
Ko Propo radio bag
TFR is offline
Old 08-14-2004, 07:44 PM
  #228
Default Advanced HSR
Hey guys, I just got my Helios yesterday and LOVE IT! I'm kinda confused on the HSR though. I race last night and today with my radio set at factory defaults, which apparently is Advanced HSR mode. Now from what I've read, I should have fried my servos, and possibly one of my recievers (or at least had problems with them). I'm using the following: KR-302F w/ KO 2113, KR-302F w/ 94357, and JR RS300 w/ KO 2123, and my radio set in Advanced HSR mode! I thought I'd have problems if I did this?
The only reason I noticed because I was trying to turn on AHSR a couple of minutes ago by using my KO 2123 servo with a 302F reciever, and I took off the module on the Helios to find it already set to high speed mode (towards the top, according to the manual), and the channels set to 2. From what I can tell in the manual I've been running AHSR with incompatable equipment...and no problems that I know of so far.
Whats up with this?
psbarger is offline
Old 08-15-2004, 12:16 PM
  #229
Registered User
tomlau's Avatar
Is the mars-R wheel avaliable as a spare part?
tomlau is offline
Old 08-15-2004, 05:56 PM
  #230
=MisFitz= NuKe's Avatar
Yeah, just call up Robert or Naka at KoPropo USA (310-532-9355) and ask them for one...
=MisFitz= NuKe is offline
Old 08-16-2004, 11:22 AM
  #231
Default Re: Advanced HSR
Whats up with this?
It may work but I wouldn't guaranty it. You may run into problems later.
KO PROPO Staff is offline
Old 08-16-2004, 11:23 AM
  #232
Yes it is available. The part number is 16077.
Old 08-17-2004, 01:33 AM
  #233
HarshGuy's Avatar
This is probably an obvious answer, but want to double check, I have a mars R with a *ton* of rx/tx chrystals, will my crystals work with this new rx/tx?
HarshGuy is offline
Old 08-17-2004, 01:35 AM
  #234
As long as they are the same frequency (27mHz xtals in 27mHz radio)
NismoSkyline17 is offline
Old 08-17-2004, 11:08 AM
  #235
All KO crystals can be used in KO radio systems as long as they are the correct frequency and band for the radio. 27MHz FM, 75MHz FM, 27MHz AM.
Old 08-18-2004, 12:23 PM
  #236
forty6's Avatar
KO PROPO Staff,
Does shortening the servo wires void the warranty? I have some appropriate connectors and I just want to check. Thanks.
forty6 is offline
Old 08-18-2004, 01:37 PM
  #237
Originally posted by forty6
KO PROPO Staff,
There is no warranty on servos. We do back manufacutre's defects and that is about it. Changing the servo lead isn't a problem unless you wire it wrong and damage the PC board.
Old 08-19-2004, 12:33 AM
  #238
theisgroup's Avatar
are the modules the same for the mars, mars r, and helios. what I am asking is are they compatable. If I take my mars 27 and put in my helios?
theisgroup is offline
Old 08-19-2004, 11:15 AM
  #239
The modules may look the same but they are in fact different. The Helios modules are a higher output of RF signal. The Mars modules are the same, just different colors for the different radios.
Old 08-19-2004, 04:03 PM
  #240
mo
mo's Avatar
I plan on getting a Helios as soon as my M8 sells and I have a question about receivers. I have some receivers from my old KO Mars EX-1 2000 edition. Will they work with the Helios and do they ever need to be sent in for tuning? Thanks.
mo is offline
