KO PROPO EX-10 Helios q's >
Old 02-27-2010, 05:32 PM
  #2206
hanzo3's Avatar
Trader Rating: 55 (100%+)
I am using a Venom lipo tx pack for the ex-10 helios. Which is the correct way or polarity to plug it in and power up?
hanzo3 is offline
Old 02-27-2010, 07:55 PM
  #2207
Still Bill's Avatar
Trader Rating: 16 (100%+)
I did have the Ballistic Batteries lipo tx pack in my Helios. It is now in my new Eurus. The tx pack came with a 3-4" long 2-wire harness. This harness has two different connectors. The 3-wire connector plugs to the pins located within the Helios' battery compartment and the 2-wire connector is keyed to a connector that comes out of the Ballistic lipo tx pack.
Hopefully, your Venom made tx pack is similar.
Remove the bottom cover and 8-cell AA battery pack. Look for the three connector pins at the front of the radio's battery compartment. The pin oriented to the back side of the radio is positive (+) and the pin in the middle is negative (-). The pin towards the steering wheel side of the radio (front) is not used.
I placed a stick-on tag with a Brother label maker next to this location with the words "RED WIRE TO BACK SIDE PIN" to remind me.
Warning...Don't ever try to charge the Venom lipo pack while it is in the radio. My battery maker warned against doing so.
Hope this helps.
Bill
Still Bill is offline
Old 02-27-2010, 09:51 PM
  #2208
C5Vette's Avatar
When you are looking at it from the bottom with the back of the radio toward your body, the right pin is positive, and the middle pin is negative....It is opposite of the standard servo placement.
C5Vette is offline
Old 02-28-2010, 01:43 AM
  #2209
gubbs3's Avatar
The nice thing is if the plug is wired correctly, plugging it in backwards just won't power the radio. The negative is the center. I learned this the hard way. Fortunately, KO's service department is amazing. $48 for a full repair and quick turnaround.
gubbs3 is offline
Old 02-28-2010, 04:28 AM
  #2210
hanzo3's Avatar
My connector will not let me connect the red positive to the back side of radio. How do I switch the position of the wires?
hanzo3 is offline
Old 02-28-2010, 06:20 AM
  #2211
hacker's Avatar
Trader Rating: 141 (100%+)
get a pin and flick up the tab and pull the wire and it will come out.
hacker is offline
Old 02-28-2010, 10:15 PM
  #2212
hanzo3's Avatar
Thanks for the info. Obviously unplug the lipo from the tx when not in use?
hanzo3 is offline
Old 04-07-2010, 06:58 PM
  #2213
xtraman122's Avatar
Trader Rating: 42 (100%+)
Is there any way to adjust the tension on the trigger? Just got mine and the thing is VERY soft feeling, I'm used to a Futaba trigger.
xtraman122 is offline
Old 04-07-2010, 08:06 PM
  #2214
hacker's Avatar
I dont unplug actually. Unless you plan on leaving it unused for a while. However I get to play with my cars a couple times a week or so, and leave mine plugged in.
hacker is offline
Old 04-07-2010, 08:23 PM
  #2215
Still Bill's Avatar
RTM. It's there. Mine was too firm of a return.
Old 04-08-2010, 04:29 AM
  #2216
xtraman122's Avatar
Read the Manual? I looked through it twice, couldn't find anything. What page#, or an explanation would help too. I only found wheel tension.
Old 04-08-2010, 06:39 AM
  #2217
theisgroup's Avatar
you have to open up the radio. there is a spring in there that you can move around. but you will never get it as stiff as the futaba unless you happen to find a spring that will work. i thinl the futaba trigger is too stiff. takes too much pressure to even hold it at full throttle.
theisgroup is offline
Old 04-08-2010, 09:06 AM
  #2218
xtraman122's Avatar
Yeah, I wasn't plan on getting it quite that stiff, but halfway between a Futaba and where mine is would be nice. So I can just pop it open and there's different places for the spring or something? As long as I can get it a little stiffer I'll be happy, I'll yank it apart when i get home today, Thanks.
Old 04-08-2010, 09:13 AM
  #2219
theisgroup's Avatar
yes, different positions to mount the spring.
Old 04-08-2010, 09:54 AM
  #2220
Barry White's Avatar
What's the speed of this radio becouse it ain't mentioned here. What about the Eurus?
Barry White is offline
