Old 12-13-2008, 12:48 PM   #2146
jag88's Avatar
Originally Posted by jag88 View Post
I have a Helios with the 2.4 module.
Last night at the track the car wouldn't work while another guy had his Futaba 4PK on, as soon as he turned off my car came on.
Whats the problem ?
Originally Posted by KO PROPO Staff View Post
Yes, you should send your module in for service. There will be no charge for the service from KO PROPO America if you live in North America.
Yes ?
What's the problem ?
jag88 is offline   Reply With Quote
Old 12-13-2008, 01:59 PM   #2147
Trader Rating: 47 (100%+)
Ko Propo staff
im going to be using ex-10 with a crawler and need to use to 3rd channel its just a 2 position switch right?? is there a way to adjust the end points?? Or is there a way to do so using the pc interface??
josh short is offline   Reply With Quote
Old 12-13-2008, 07:25 PM   #2148
Tire Chunker's Avatar
Trader Rating: 16 (100%+)
Do the Mars and Helios use the same antenna?
Tire Chunker is offline   Reply With Quote
Old 12-14-2008, 02:40 PM   #2149
jag88's Avatar
Originally Posted by STLNLST View Post
So is this something that we all should do? Is there a problem with the modules?
Good question !!!!!!!!
Old 12-14-2008, 06:13 PM   #2150
It's Futaba, they are "squashing" all the channels and basically forcing you to loose your connection to receiver.
DirtyRacer is offline   Reply With Quote
Old 12-14-2008, 06:43 PM   #2151
jag88's Avatar
...so basically, if there's a Futaba 4PK around all the KO 2.4 guys are screwed ?
Old 12-14-2008, 07:00 PM   #2152
The only problem should be when you're binding the RX and TX.
Once it's bound, you shouldn't have any problems. I've ran next to a 4PK before and didn't have issues.
Old 12-14-2008, 07:22 PM   #2153
Originally Posted by josh short View Post
Ko Propo staff
You need this:
http://servocity.com/html/180o_servo_stretcher.html
Helios/KO 2.4
Mugen MTX-4 // Losi 8B // AE B44 // Mini-Z 2.4 // Axial AX10
jon123 is offline   Reply With Quote
Old 12-14-2008, 07:34 PM   #2154
have u used that servo strecher?? i heard it was a manual
Old 12-15-2008, 08:19 AM   #2155
jag88's Avatar
Interesting, I wonder what KO has to say about this (besides, yes, send it in for repair !) ?
Old 12-16-2008, 08:15 AM   #2156
jag88's Avatar
Old 12-16-2008, 08:52 AM   #2157
I am looking at buy a new radio. It's down to the 4PK or the EX10.
I have heard that the 4pk's are having thermaling, and binding issues, then I read on hear that the EX10 seems to be suffering from the same binding, channel quashing issues that the 4PK has. Can anyone comment on the issues? I am having a hardtime tying to justify buying either of these radio's if there are known issues for both systems.
Thanks in advance
Sean
savagebeing is offline   Reply With Quote
Old 12-16-2008, 09:58 AM   #2158
GFT
Default kopropo ur
Hi kopropo,
We have the same problem too. We live in Malaysia, where and what is required to be sent.
Thank you.
leong
GFT is offline   Reply With Quote
Old 12-16-2008, 10:11 AM   #2159
Trader Rating: 33 (100%+)
Originally Posted by jon123 View Post
KO Propo staff,
It's a GTB, asks for max setting. So I use 150?
I've been using 100. I know top speed will be the same, but what's the difference otherwise.
From what I have experianced, if you use 150 the throttle curve will be longer, thus more precise control. Also if you limit the end piont, which I do in off-road, it gives you a lot finer adjustment. For example, if I want to take the throttle end point down to 1/2 speed, I would adjust the 100 setting down to 50, but the 150 setting goes to 75. Hopes this helps and not confusing.
chensleyrc1 is offline   Reply With Quote
Old 12-16-2008, 10:27 AM   #2160
If you have a problem with your system, then you should send it in. I don't believe that there is anything else to say. KO PROPO America will only service North American customers.
So if you live abroad (anywhere else in the world) you should contact your local KO distributor for repairs and service.
KO PROPO Staff is offline   Reply With Quote
ko propo helios alexisonfire Australia For Sale/Trade 7 03-06-2008 04:19 AM
KO PROPO EX-10 Helios 40 Mhz jca2000au Australia For Sale/Trade 0 12-06-2007 09:03 PM
**EX-10 HELIOS KO PROPO*** nsupra R/C Items: For Sale/Trade 8 08-14-2006 09:11 PM
Ko Propo Ex-10 Helios hurley081182 R/C Items: Wanted to Buy 1 04-03-2005 07:58 PM
F.S.> KO Propo Helios... plus Bwadd2002 R/C Items: For Sale/Trade 7 05-19-2004 09:40 PM
