Old 07-29-2004, 04:36 AM   #181
acutts's Avatar
Anyone got a part number for the bling bling .. gold screws?
acutts is offline   Reply With Quote
Old 07-29-2004, 06:10 AM   #182
theisgroup's Avatar
i don't have the manual in fron tof me, but you need to re-adjust the "vr" i believe. It basically is to setup the resistance at full lock for the steering . What is happening is the radio does not think that it is at full lock. so the steering mechanism is not set correctly, does not provide enough on the variable resistor to signal full lock.
Originally posted by OleC
Hi,
a couple of days ago one of the guys I race with came over to me with his Helios. He was trying to alter the "steering" balance" but he could only make changes to the right side. When you are in the steering balance meny you rotate the steering wheel all the way to the right to make the * appear indicating that you can now make adjustments. But when he rotated the steering wheel all the wat to the left ,the * didn't appear. So he could not adjust the left side.
So I checked my Helios and it was the same!
Is there any other setting that causes this? I have adjusted the steering balance earlier but now I can only adjust one side.
What's going on?
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 07-29-2004, 06:15 AM   #183
theisgroup's Avatar
from ko staf post on page 3
Aluminum Light Weight Screws # 17002
yang lai
Old 07-29-2004, 11:39 AM   #184
Hi,
What's going on?
Just like theisgroup stated, you must go to the function called Adjust VR. This will reset the pots in the radio. If they do not reset, then you know that you have a bad pot will need to send it in for repairs. I tell all of our pro-drivers to do this at least once a month to make sure that everything is working correctly. It is an easy way for your to calibrate the pots yourself.
KO PROPO Staff is offline   Reply With Quote
Old 07-29-2004, 01:11 PM   #185
forty6's Avatar
What is the size of the gold screws? I would like to see if I can find Ti screws in that size.
forty6 is offline   Reply With Quote
Old 07-29-2004, 01:32 PM   #186
Matt Howard's Avatar
I don't know if this has been asked already, but is KO ever going to release a synthesized module and receiver? I've used KO transmitters for the past 10+ years and the only reason I would change is to use the synthesized setup to get away from crystals
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 07-29-2004, 02:09 PM   #187
=MisFitz= NuKe's Avatar
Send a message via AIM to =MisFitz= NuKe Send a message via Yahoo to =MisFitz= NuKe
Yes...
=MisFitz= NuKe is offline   Reply With Quote
Old 07-29-2004, 02:33 PM   #188
ngo8's Avatar
Send a message via ICQ to ngo8
yes it was asked but ko said no not for helios but in the futre for lower models maybe rtr upgrade kit or something .
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 07-29-2004, 02:39 PM   #189
litespeed-dom's Avatar
Hi,
What's going on?
I have the same problem with mine too, I just crank the wheel a bit more left (ahm ahm!) using some force and the asterick will show up on the menu screen. I know, it's not right by something I just live with.
BTW, is anyone's Helios suck up batteries like in no time? Compare to the Type 2000R, I have to change alkline batts more often???
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 07-29-2004, 04:58 PM   #190
not for the Helios but for lower models? doesn't make sense to me why they would do that
RCTech #361
Old 07-29-2004, 06:32 PM   #191
Hebiki's Avatar
Trader Rating: 26 (100%+)
Dom
hey dom.. i have two helios radios.. and both are fine in terms of battery life. in one radio, i use the ko battery pack and charger. my 75band radio uses energizer rechargable batteries. the ones that are esp. designed for digital cameras. you can get 4 + charger for about $30 at best buy. i charger all 8 batteries the night before a race, and the next race day i can go a whole day without charging. one thing i did notice is battery life is shortened whenever i make a lot of adjustments. but once all my adjustments are done, im okay.
- c
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 07-29-2004, 06:38 PM   #192
Hebiki's Avatar
Default Batteries
here are the ones i use:
Charger:
http://www.bestbuy.com/site/olspage....0&type=product
Batteries (1850mah NIMH)
i have a ton of these at the house, i use them for remote controls, my rc radios, wall clocks and my digital camera. great batteries too bad they're not matched! HAHAHAHAH
Hebiki Design Works
Old 07-29-2004, 08:13 PM   #193
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Default This is a simple fix.
Dom
I had same problem and called ko...you had to go into the adjust vr and recalibrate the radio..it is real simple..get into the screen turn full left and full right and full throttle and full brake and it resets the radio.
Consult the manual on the adjust vr if you are still unclear.
Jamie
J.Gonzalez is offline   Reply With Quote
Old 07-29-2004, 08:16 PM   #194
J.Gonzalez's Avatar
oops they already listed the fix.
Old 07-29-2004, 08:22 PM   #195
Hodapp's Avatar
Send a message via AIM to Hodapp Send a message via Yahoo to Hodapp
Senna is God!
Hodapp is offline   Reply With Quote
ko propo helios alexisonfire Australia For Sale/Trade 7 03-06-2008 04:19 AM
KO PROPO EX-10 Helios 40 Mhz jca2000au Australia For Sale/Trade 0 12-06-2007 09:03 PM
**EX-10 HELIOS KO PROPO*** nsupra R/C Items: For Sale/Trade 8 08-14-2006 09:11 PM
Ko Propo Ex-10 Helios hurley081182 R/C Items: Wanted to Buy 1 04-03-2005 07:58 PM
F.S.> KO Propo Helios... plus Bwadd2002 R/C Items: For Sale/Trade 7 05-19-2004 09:40 PM
