KO PROPO EX-10 Helios q's >
Old 02-14-2007, 11:10 AM
  #1921
JFCJ's Avatar
Trader Rating: 31 (100%+)
Robert,
Thanks for the quick turn-around on my Helios Tx.
James
JFCJ is offline
Old 02-14-2007, 11:55 AM
  #1922
K_King's Avatar
Trader Rating: 41 (100%+)
I'm a bit confused here, so I appologize for asking this for the 58th time.
For Spektrum (regular not pro) use NORMAL
For Spektrum PRO can you use the High Speed mode if you are using a Digital Servo? I'm using the KO High Speed Digital servo (I forget the name but its the top of the line one). Currently I am using Normal, but I'm wondering if I could use High Speed with a Pro Module and a Digital servo.
K_King is offline
Old 02-14-2007, 02:44 PM
  #1923
Mr. Shookie's Avatar
I am not 100% but I use Spektrum Pro and I use only Normal mode. The HSR is for the KO Module only as far as the manual explains it.
-Shookie <><
Mr. Shookie is offline
Old 02-22-2007, 12:48 AM
  #1924
Hi all,
I was wondering what you guys are using or recommend on a battery pack for this transmitter and where can I get it online -would be much appreciated.
Thanks in advance.
Eagle_iiZ is offline
Old 02-25-2007, 10:20 PM
  #1925
dawgmeat's Avatar
is there a way to re-calibrate the trigger my neutral setting is way off with the Keyence pro esc
dawgmeat is offline
Old 02-26-2007, 06:04 AM
  #1926
theisgroup's Avatar
adjust the vr setting. it does both throttle and steering pots. and then set throttle endpoints to 100% and trim to 0 and then reset your keyence.
theisgroup is offline
Old 02-26-2007, 09:21 AM
  #1927
dawgmeat's Avatar
when I go to adjust VR it only go to steering
dawgmeat is offline
Old 02-26-2007, 11:04 AM
  #1928
theisgroup's Avatar
page 56 of manual. if you need it, you can download from ko site.
Old 02-26-2007, 12:11 PM
  #1929
dawgmeat's Avatar
thanks
dawgmeat is offline
Old 02-26-2007, 04:14 PM
  #1930
axle182's Avatar
Trader Rating: 18 (100%+)
I need some help guys. I bought a very nice Helios Competition, and yesterday, i tripped over a board while retreaving my car, landed with all my weight on the handset, and snapped it in a few places. Where would one send it to be fixed, and at a guess, would it be expensive? It doesnt power up, the switch board i could see has a break in it. I had an extended wheel on it, but nothing above the grip and the switch have a problem, the controller partially snapped at the top of the hand grip and the switch.
At a guess, im thinking a new case, switch board, a little resoldering and it will be like new. Well not only is it a guess, its what im hoping it is!
Anyone dealt directly with KO support, anyone sent in gear? How are they?
axle182 is offline
Old 02-26-2007, 05:11 PM
  #1931
Hebiki's Avatar
Trader Rating: 26 (100%+)
not sure if you would go through Ko Propo USA..but contact Robert Morris at [email protected]. he'll be able to help you with getting your helios repaired.
Hebiki is offline
Old 02-26-2007, 05:38 PM
  #1932
ChrisP's Avatar
KO Propo USA support was super fast and friendly. Give Robert a call and he'll provide you with all of the information that you need to get your radio fixed up in a hurry.
ChrisP is offline
Old 03-17-2007, 11:13 PM
  #1933
shodaman's Avatar
Default Potentiometer?
Does anyone know what type of potentiometer the JR Z-1 uses for steering? I think that I may have a bad one..
shodaman is offline
Old 03-22-2007, 10:34 PM
  #1934
chicmagnet's Avatar
can i use the high speed mode on spektrum pro??
chicmagnet is offline
Old 03-23-2007, 09:57 AM
  #1935
TheCoolCanFanMan's Avatar
Ok
Just bought a Helios 10 and would like to know which position the switch behind the module should be, high or low? as I have a 2.4 module, or dosent it matter.
Please answer as soon as pos as im going racing tonight and would like to know
Cheers Malc
TheCoolCanFanMan is offline
