KO PROPO EX-10 Helios q's >
Old 02-09-2007, 09:36 PM
  #1906
theisgroup's Avatar
run the adjust vr and re-calibrate the steering pots. they are off and at full lock, the helios does not think it is at max epa
theisgroup is offline
Old 02-09-2007, 11:15 PM
  #1907
JasonC's Avatar
Trader Rating: 120 (100%+)
i had the same problem once, i just did a memroy reset.
JasonC is offline
Old 02-10-2007, 07:47 AM
  #1908
Scottmisfits's Avatar
No need for a memory reset. Very few people seem to know about the VR function. Basically it set's your TRANSMITTER end points. Once that's set up, now you can set the end points for the car.
Scottmisfits is offline
Old 02-10-2007, 08:08 AM
  #1909
Anthony.L's Avatar
Trader Rating: 36 (100%+)
Robert/KO, what's the update on the 2.4 system for the Helios?
Anthony.L is offline
Old 02-10-2007, 08:14 AM
  #1910
carsrule692's Avatar
Hey i have some big problem. I bought my helios and 2 reciver a month ago. A month later my car is uncontrollable. Both cars the 1/10 and the 1/12. I have no i dea what it is. I doubt the recievers are no good, cause whats the odd of to brand new recivers going bad at the same time. And the controller is in great condition, never dropped or anything. If i turn the car on first nothing happens. Once i turn the helios on. The cars wheels spin turn everything and im not touching a button. It had been working to so its not my settings. I am unable to use my controller do to this problem. ANy help would be greatly appreciated.
carsrule692 is offline
Old 02-10-2007, 03:01 PM
  #1911
Default what mode for spectrum
HI i have a ex10 with spectrum system and digital servo what setting should the responce mode be in?
cheers
kev-h
kev-h is offline
Old 02-10-2007, 03:06 PM
  #1912
rc_bam226's Avatar
cheers
kev-h
Normal
rc_bam226 is offline
Old 02-10-2007, 06:40 PM
  #1913
RCSteve93's Avatar
What are you guys using as a case for your KO Propo Helios? I have been using the KO Propo soft transmitter case, and the antenna for my spektrum module broke, since it is not hard enough. I am looking for a hard case (aluminum, plastic, etc) that will fit the Helios with the drop down wheel attachment, and a spectrum module. Thanks ahead of time.
RCSteve93 is offline
Old 02-10-2007, 06:41 PM
  #1914
rc_bam226's Avatar
I've been using a Speedmind case, they are distributed through www.magmarc.com
Old 02-12-2007, 09:30 AM
  #1915
afiq- Just like Theisgroup said, do the "Adjust VR" function. If you can not finish this calibration, then the pot is damaged.
Anthony.L- Don't know yet.
carsrule692- If you turn the car on first, the Rx should pick up a very weak signal and should be out of control. Never turn on the car first. If turning on the Tx and then the Rx yeilds no response it could be serveral things but with no response when you turn on the car first sounds like a bad Rx to me. Make sure you have the Tx crystal in the Tx and the Rx crystal in the Rx. Check to make sure that you have not damaged the module pins in the Tx. Other then that, you may have to send it in for repairs.
KO PROPO Staff is offline
Old 02-12-2007, 02:52 PM
  #1916
i use a yeah racing case its not all aluminium but protects it well there is also enough room in the cut out to protect my spectrum module without removing it these can be found cheap on a well known auction site.
take a look at yeah racing website.http://www.yeahracing.com/catalog/pr...roducts_id=416
kev-h is offline
Old 02-13-2007, 04:57 PM
  #1917
THanks KO
The problem was the crystals were no good. Can i send them in and get new ones.
Old 02-13-2007, 07:32 PM
  #1918
Thistle's Avatar
Rc_Bam226... In regards to your questions regarding the ICS adapter, I've been using one on my laptop with a usb adapter. I too, have had problems connecting... turned out the speed control wasn't in "communication" mode.
This might be worth checking, the next time you try...
Thistle is offline
Old 02-14-2007, 08:28 AM
  #1919
rc_bam226's Avatar
Actually, I was using the adapter for the Helios. I had my unit serviced, apparently the adapter for the Helios was faulty. Had the adapter replaced, and its working now. Thanks KO Staff for the support.
Old 02-14-2007, 10:04 AM
  #1920
Originally Posted by carsrule692
THanks KO
Crystals are not repairable. If they were new and you have a receipt, then we will replace them.
