KO PROPO EX-10 Helios q's
#1831
ko staff, you have pm
#1832
Originally Posted by vabroom
I just got a much more lipo tx battery for my helios.
Question - the male connector is not a futaba plug, what kind of connector does KO use for their tx? And where can I order some?
Question - not in line with the above question, but what is the thread size and length of the gold screws.
just switch the positve wire, to the other side, then it will work
#1833
ok, so I finally got my hands on a 302f and some KO crystals (YAY!) but now that I have instaled them in my cars, all I can get out of them is smoe serious glitching. If I turn on the car first, the steernig servo centers its self just like it should. then I turn on the radio and the steering servo goes crazy, steering left and right spontainiously, and the throttle just kinda does its own thing. So I have narrowed it down to my TX. And since it is a Helios, I figured this is the best place to ask.... Is there some setting that im missing? I havnt changed anything from the stock settings, so I would assume everything should work just fine. Help?
#1836
Originally Posted by JasonC
did you buy new or used?
make sure you have the RX crystal in the reciver and the TRX in the transmitter
#1837
#1838
Originally Posted by K_Spec_RC
Transmitter is new, modual is new, 302f is used, crystals are used. TX in TX, RX in RX. ive tried with 2 cars, and 2 diferent ESC and servo combonations. Still the same issues. Raceace said it might be the TX.
have your tryed a diffrent reciver? almost sounds like the ant. wire needs to be replaced.
#1839
Thanks, Jason, it work! Another question, do you know where I can get a female plug so that I can charge the battery?
#1840
I have a set of KO crystals that give me the same problem. They were ones I got used, but bought a new set of the same frequency and have had no problems. You might have a bad crystal.
#1844
#1845
Originally Posted by Mr. Shookie
Hey Robert,
ANy Chance KO is going to hit us with a 2.4Ghz system anytime soon?
Just wondering......
-Shookie <><
-Shookie <><
