KO PROPO EX-10 Helios q's >
Old 05-26-2004, 04:12 PM
  #151
littledog's Avatar
Originally posted by webspinner
Andy, email KO.
Proud,I did not feel like waiting the week it takes them t email you back.I figured someone in here knows or has heard of someone who might know answer.
littledog is offline
Old 05-26-2004, 04:24 PM
  #152
Our email is usually a one day turn around (weekdays), company policy. You can not use the Mars series modules in the Helios. The modules are not as strong as the Helios module and can cause your car to lose range and control.
KO PROPO Staff is offline
Old 05-26-2004, 08:37 PM
  #153
littledog's Avatar
Old 05-27-2004, 01:25 AM
  #154
litespeed-dom's Avatar
Not sure if this is a known fact already.... Just got my replacement Type 2000R in the mail today, I used theType 2000R with the 302 receiver and it works fine on the bench, (I somehow thought this combo isn't possible). On the other hand, as expected I can use the Helios with 297 receiver, but have to switch the mode to "N" behind the module.
The Type 2000R is for my girlfriend to race her sedan, now we have HIS and HERS KO gold radio.....kinda digusting!
litespeed-dom is offline
Old 05-27-2004, 02:16 AM
  #155
TC3
TC3's Avatar
Originally posted by TC3
does the futaba 9550 servo worke with the helios in Advanced HSR 2channel mode ?
answer plz
TC3 is offline
Old 05-27-2004, 07:09 AM
  #156
theisgroup's Avatar
hey guys, what parts do i need to get the helios to talk to my laptop. I just pick a helios up and want to order the cable for it.
TIA
theisgroup is offline
Old 05-27-2004, 11:06 AM
  #157
ngo8's Avatar
tc3 offcourse it will any didgital servo will work with advance hsr .
ngo8 is offline
Old 05-27-2004, 11:16 AM
  #158
TIA
http://www.shopatron.com/product/pro....1053.56.0.0.0
Old 07-04-2004, 07:29 PM
  #159
Titan's Avatar
Default Using analog servos
Hi Guys,
Would like to ask if the standard analog servos will work fine with the helios. I'll be using them while I save for the digital servos. A couple of people have mentioned that they will just burn the standard servos, is this a fact?
I just bought a speedmind carbon look Helios soft case. Will it fit the Helios mounted with the steering extension? I'm still waiting for my Helios to be delivered and I bought the bag just in case...
Looking forward to your reply.
Regards,
Titan
Titan is offline
Old 07-04-2004, 08:04 PM
  #160
=MisFitz= NuKe's Avatar
Yes, dont worry about the Analog servos, I used to use them in my 1/8th scale gas car on the throttle. Altough, per the instructions in the manual, you will see that you have to flip a switch on the radio, located behind the module, and you will have to change the mode within the radio's software. But the instructions go into more detail. I just dont have that section memorized yet .
-Mike Patterson
=MisFitz= NuKe is offline
Old 07-06-2004, 12:01 PM
  #161
Default Re: Using analog servos
Originally posted by Titan
Hi Guys,
Regards,
Titan
Titan,
You can use analog servo with the Helios, but only in Super HSR (High response 3CH mode) or Normal mode (switch behind the module). You CAN NOT use analog servos in the Advanced HSR (High response 2CH mode).
Old 07-06-2004, 01:13 PM
  #162
TC3
TC3's Avatar
thx m8
TC3 is offline
Old 07-06-2004, 01:42 PM
  #163
wothrottle's Avatar
let´s see some custom alarm tones,the new ko site has only the downloadable versions,but I need the numbers to manually type in.some sheet music would also be fine:Fall Guy,Dukes of Hazzard,A-Team,something like that would be great
wothrottle is offline
Old 07-13-2004, 05:32 PM
  #164
Titan's Avatar
Default --
Hi Guys,
I just got my Helios a few days ago... and was setting the ABS and TH Acceleration. I noticed when I activated the red lights started blinking, even after and when I turn on my radio. Is this normal? I was thinking the lights would blink when I am using the brakes or throttle.. The lights are pretty alarming, like a bomb!
Titan is offline
Old 07-13-2004, 05:34 PM
  #165
Yup, it is normal. Whenever you have one of those features "activiated" the corresponding lights will blink.
Dom
