KO PROPO EX-10 Helios q's >
Old 01-23-2006, 05:06 PM
  #1561
Motorman007's Avatar
Trader Rating: 89 (100%+)
Robert thank for the super fast shipping.
I did not think it would be here so fast.
i may go racing this weekend.
With Love
Dibs
Motorman007 is offline
Old 01-23-2006, 09:33 PM
  #1562
I just purchased a EX-10 and when I turn it on the transmitter module got hot. Is this normal? Or is the the radio bad? It smells like an eletrical short. Has anyone else had this problem?
Thanks,
Joe
Joe Maxey is offline
Old 01-24-2006, 10:00 PM
  #1563
Ill Factor's Avatar
Hey guys Im looking to buy a Helios and wanted to know which was better 75mhz or 27mhz?
Ill Factor is offline
Old 01-24-2006, 11:59 PM
  #1564
Yeti35's Avatar
For me it was the one with no module at all since I was already using Spektrum and just got another module!!
Yeti35 is offline
Old 01-25-2006, 12:03 AM
  #1565
BringItOn's Avatar
Thanks,
Joe
it gets warm, but not hot, prob 40degC
BringItOn is offline
Old 01-25-2006, 01:03 AM
  #1566
James's Avatar
hey crew, just thought I'd put a good word in for a case i bought for my helios recently.. it's from YEAH RACING.. and available at http://www.rcmart.com/
it's a metal hardcase with foam inlay, provision for spektrum module, extra xmitter batt, provisions for xtal boxes, modules, receivers, and a removable cut out for wheel extension, etc.
very nifty.
James
James is offline
Old 01-30-2006, 10:02 AM
  #1567
Mr. Shookie's Avatar
Default PM ALERT
KO STAFF......YGPM
-Shookie <><
Mr. Shookie is offline
Old 01-30-2006, 02:13 PM
  #1568
Mark G's Avatar
hi i was looking threw all the menus on the ko and i found the HIGHPOINT it was at 100 and then u put it to 150 and i seamed faster can some one explaine wat highpoint is to me. just dont know if i lose batt power faster if its at 150
thanks
-mark
Mark G is offline
Old 01-30-2006, 05:27 PM
  #1569
beer_drinker's Avatar
Maximum throttle is maximum throttle, so it was all in your head The only way you could have been faster is if your esc was setup with the highpoint above 100 and then you put it back to 100 afterwards. Highpoint is just the maximum electronical throw in one direction. Throttle highpoint is not important on ep cars as we use escs.
edit: actually, the car could have felt faster as you would have full throttle on your esc at 2/3 throttle on your transmitter. This may have given you a little more punch.
beer_drinker is offline
Old 01-30-2006, 05:50 PM
  #1570
JasonC's Avatar
Trader Rating: 120 (100%+)
james:
does the radio with the drop down wheel fit in the yeah racing case ??
JasonC is offline
Old 01-30-2006, 06:08 PM
  #1571
beerbarron's Avatar
Does anyone have links to custom tones besides the ones on KO's website. I am sorry if this had already been asked.
beerbarron is offline
Old 01-31-2006, 12:03 AM
  #1572
James's Avatar
Originally Posted by JasonC
james:
Yeap. it's a removable foam cut-out. much like the cutout you can remove in the bottom of the case for spare batt holder, and spektrum.
(remove the foam as already cut, and the spektrum fits, wheel ext fits, etc)
very neat case. very professional.
I have my helios, neck strap, fm/spektrum modules, and 21 sets of crystals in the case and still have room / provision for drop down ext, and spare batt holder.
James is offline
Old 01-31-2006, 12:05 AM
  #1573
James's Avatar
the other day i noticed that when I swapped from my spektrum module back to the FM module.. one of the pins in the transmitter was half pushed in.. like, lower than the other pins!
I ignored it and continued to race, it all still worked fine with both modules. But then I thought I'd try to pull the pin back out.
I pulled the pin back up, level with the other pins, without hassle.
I'm wondering, is the unit damaged? are these pins supposed to be hard-soldered? or do they actually have the ability to slide in like that?
unit still works fine, but wonder if i should get it replaced?
James
James is offline
Old 01-31-2006, 12:08 AM
  #1574
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Hi, this is a newbie post. Just got a Helios, my first KO ever. Been a long time Airtronics guy. Wanted to try something different after having Spektrum problems on my M11, don't blame the radio but I do blame the Spektrum. Thought I would try the KO 27 with a split crystal. Anyways, opened the box and took one look at the manual. Dang! Will Robert be holding a seminar anytime soon? It looks like a workbook for a two unit college course. I'm sure I'll figure it out eventually.
Okay questions;
1)I have a bunch of 27 Hitec receivers that I used with the Airtronics, can I now use it with the KO using KO crystals? Will it also work with the splits?
2)I was also shopping for some KO receivers and found some for sale. They are the KR-297FZ on 27. Will this receiver work with the Helios and in what capacity? Will it also work with the splits?
3)I have a KO VFS speed control and I just picked up a used programmer with no manual. How is this used to program the controller? Is there a link cable I need to get?
YR4Dude is offline
Old 01-31-2006, 11:49 AM
  #1575
dodo's Avatar
some help here
2) KR-297 FZ will work with the helios, but it won't work on HSR, just normal speed.
3) just plug the ESC cable to the setting card (the same cable that you plug to the receiver), you might want to address this question at VFS-1 forum.
enjoy ur new 'gadgets'!!
dodo is offline
