NEED HELP ON SUSPENTION SET UP >
Old 06-27-2009, 07:13 AM
capturefx's Avatar
Default NEED HELP ON SUSPENTION SET UP
hello everyone, i just installed oil filled adjustable shocks with adjustable spring rate on my hpi e10 that came with plastic suspension. my question is how Do i know that i have the suspension set up correctly,height is not an issue but im kinda lost on the spring set up (like too hard or too soft on the springs??) i noticed that with the old plastic suspension i could make the car go sideways( does that mean that the suspension was too hard?) and now that i have the new oil filled ones it seems to stick to the ground and i cant get this thing to spin out or go sideways which is good and i think it will make the car take the turns faster if i race in the track.( should i leave this set up alone ??) someone suggested that i should harden the spring in the rear just a little.. is this good? can someone please help direct me to the right direction to set up this suspension. thanks
http://www.hpiracing.com/graphics/pa...88054_004m.jpg
capturefx is offline
Old 06-27-2009, 07:28 AM
20 SMOKE's Avatar
Trader Rating: 103 (100%+)
look over this and it will help you,if you can print some of it out
http://www.rc-setup.com/guide.html
http://users.pandora.be/elvo/
20 SMOKE is offline
Old 06-27-2009, 09:54 AM
capturefx's Avatar
wow! these are awesome information , thank you so much!
Old 06-27-2009, 08:09 PM
#88driver's Avatar
Here is another good site
http://www.richardchang.com/hobby.php?topic=tcsetup
#88driver is offline
Old 06-28-2009, 06:29 AM
capturefx's Avatar
Originally Posted by #88driver View Post
thank you!
