Old 06-26-2009, 10:13 AM   #1
Ritchie T's Avatar
Arrow Wet Setup
Ok im now in the position to have a wet car. Its a Schumacher mi3 with Brushed Peak 19t and waterproof MRT MX. Im going to seal the rest of the electrics, however i have no clue about setting up a wet car.
Where should i start ?
Ritchie T is offline   Reply With Quote
Old 06-26-2009, 11:38 AM   #2
Skiddins's Avatar
It still depends on the track, but....
Softer springs
Softer oil
Lay front shocks down
Stand Rear shocks up
Softer front roll bar (you might find it better without any roll bars at all)
Less Castor
More Ackermann
Negative throttle expo (-30 or so)
The main problem in the wet is getting the car to turn in (again it depends on how much grip the track has), but overdoing the settings to achieve this will mean it wants to swap ends coming out of the corner.
Also, get some spare bearings as you are going to knacker some of them.
Spray some GT85 into the bearings before and after each race (it's basically WD40 with teflon in it).
The wishbones could well swell up slightly after some wet use so make sure they are still free to move on the pivot pins.
Will post again if I think of any more
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 06-26-2009, 01:07 PM   #3
Ritchie T's Avatar
Softer springs
Softer oil
Less Castor
More Ackermann
Thanks for the reply ! So basically soften it all up n make it less reactive n twitchy with no punch.
Also would it work better with a higher ride height?
BTW its for Bedworth this Sunday, it keeps saying its sunny one minute then thunder storms the next!
Old 06-26-2009, 02:28 PM   #4
IndyRC_Racer's Avatar
I suggest replacing any steel parts with aluminum or titanium. Steel screws and hinge pins will want to rust if left wet after racing.
Unless the driver's stand is covered, you will also want to consider coming up with something to cover your radio racing. With the advent of Spektrum/DSM radios, you don't have to worry about a big antennae poking out of the plastic you have covering your transmitter. Still, it is better to be safe than risk damaging the most vital part of your radio gear.
The last thing to consider is a dedicated set of wet tires. Depending on how you have been prepping your tires, they may not react well to wet conditions. If you have used any oil based traction compound that has soaked into the tires, chances are that it will affect grip.
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Old 06-27-2009, 03:23 AM   #5
Ritchie T's Avatar
Oh crap i forgot about the transmitter, i know you can buy covers and things but its for this Sunday. Any ideas on making a makeshift one?
I have some wet tyres from a really long time ago i think theyre Pit Shimizu. I dont think theyve ever had anything put on them.
Thanks for the post
Old 06-27-2009, 03:47 AM   #6
Skiddins's Avatar
The tradition if you don't have right stuff is....a plastic carrier bag
This can sometimes help create some roll, if there are puddles then definitely, If there is any standing water etc anywhere I will run 7-8mm ride height and I've backed the droop screws right out.
From our recent national at West London
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 06-27-2009, 03:50 AM   #7
Ritchie T's Avatar
Niceee, im off to Sainsburys
Old 06-27-2009, 03:59 AM   #8
Ritchie T's Avatar
Ok ill jack the height up a bunch.
Kinda looking forward to it hammering it down now!
Ha nice picture which ones yours?
Old 06-27-2009, 04:05 AM   #9
Skiddins's Avatar
Neither, I think what was a later Mod heat. But I did race in those conditions with brushless, was going very well until I got some moisture in the sensor lead
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Tamiya TA05 Touring Sedan kentech Electric On-Road 11403 06-21-2017 04:10 AM
XXX-CR Thread Matt Howard Electric Off-Road 5778 04-03-2017 01:45 PM
BANZAI Motors Eddie Garrison Team and Company Discussions 11666 09-09-2015 01:43 PM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 08:38 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
TQ Racing SX8 vino1 Nitro Off-Road 3254 11-15-2012 03:53 PM
German Touring Car Outdoor Nationals V12 Electric On-Road 121 09-29-2004 08:56 AM
