bearing oils
bearing oils
what are the best bearing oils, for motors and general use???
can i use ultra thin oils like the trinity royal in all bearings or it works great only in motor bearings???
how about trinity oils, fantom gogo juice ans zubak speed juice??
thanxxx.....
thanxxx.....
they're ok but.....
Those are OK but I use castrol sewing machine oil for all my bearings. This is also called light machine oil and it is exactly the same as all the special to hobby type and cost 1/4 as much.
Hope this helps
Gary
Hope this helps
Gary
thanks.....
and do you use this oil in both motor and car bearings?/??
i have noticed a lot of guys using Mobil 1 for bearing oil, get synthetic in straight 30 weight, less additives. and a quart would last an entire racing career
I have found that Niftech micro bearing oil seems to be the best. I have used it for many months. It has a soaking affect into the bearings and makes what seemed to be worn out bearings smooth again. The best part is that it only takes a few drops.
I just relubed the bearings with BarDahl Engine additive #1. In the past this was one of the best at leaving a nice lube coating on metals. Its about 10W oil. I passed on the Mobil 1 and will try this one out.
